AEM wideband, connect to ECU or serial?
Old Nov 29, 2017 | 03:47 PM
Biggiesacks's Avatar
Originally Posted by heel2toe
Lol maybe Im using 1 byte load then. My buddy does my tuning so Im sheltered for the most part from that. I ask the questions out of curiosity but he's the smart one thankfully not me!
I see your point however, it was more a question of well, sure its faster in theory but is it something that is measurable? That I do not know.
measurable absolutely, necessary though is relative. With a fixed sampling rate, the fewer samples you request the sooner each sample will be updated.
So lets say I can only give you 1 sample per second, and you are asking me for 5 different samples. That means you will only get an update per sample every 5 seconds. Now if you reduce that to 4 different things that means you will get an updated sample every 4 seconds. The sampling speed doesn't change, but how quickly you get updated samples does based on the total amount of different samples you are asking for.
Old Nov 29, 2017 | 06:16 PM
jingalalahoe's Avatar
Just connect the wires from the 4 pin connector to the rear O2. The wideband will be powered by the MPI circuit which means it wont die while cranking, plus you can log on Evoscan easily without havinng extra wires or adapters. Win win situation.
Attachment 325045
Old Dec 9, 2017 | 09:10 AM
miragevo's Avatar
Veteran: Navy
Wire in a toggle switch that you can use to get it inspected...one way powering the gauge...the other way for inspection.
PATRICK B.
Mar 11, 2015 01:51 PM
steveyrich
Apr 12, 2012 09:00 AM
MattGold
41
Aug 24, 2006 08:53 AM
DSMotorsport
Jan 26, 2006 12:50 PM
