boost and uego
Old Apr 4, 2018 | 05:06 PM
nor11384's Avatar
FCOTM Winner
boost and uego
Hey guys im trying to setup boost and wideband reading on evoscan. For boost i have an item called omni map and it reads -6 psi at idle when vacuum is -11, -12. Another item called boost (mdp) but that one reads -1 at idle. I looked on here and it says to set the value depending on altitude but its set right. Im at sea level.
I made a serial cable connection for the uego. Under the wideband wdb settings which uego do i choose? Also, where it says select serial comport nothing happens.
Old Apr 4, 2018 | 05:42 PM
2006EvoIXer's Avatar
Nice to see you diving into this.
Old Apr 4, 2018 | 07:04 PM
nor11384's Avatar
FCOTM Winner
Thx man. Im trying. Just need some info and a little bit of help then ill try my best to get r done.
Old Apr 4, 2018 | 09:58 PM
codgi's Avatar
Post a screen shot of EvoScan and the port options. It's been a while but if I see that I can probably remember
J.Js evo9mr
Apr 9, 2016 07:48 PM
PATRICK B.
Mar 11, 2015 01:51 PM
Kerr
Feb 5, 2007 04:56 AM
supradan
Dec 23, 2006 12:21 PM
