Electrical issues...
Old May 29, 2018 | 03:53 PM
nor11384's Avatar
FCOTM Winner
Hey guys so im having a problem with something draining my battery. Battery keeps getting drained after sitting for about a week. When i install the battery theres big sparks when connecting the negative terminal. Positive first then install negative. So obviously theres a parasitic drain. Now when this happens it takes a 30a fuse under the hood with it. Some times i noticed that a second 30a fuse goes. Im putting up a pic that shows these fuses. When i change the fuse it seems to be fine unless i uninstall battery and reinstall. Now, car has an alarm and music system (subwoofer etc). How can i go about diagnosing this? Should i just find a way to uninstall alarm and see if its fixed and then system? What does the fuse have to do with this? What is causing them to blow? I know a little about electricity but not much. I can figure it out with some guidance. thx...
Old May 29, 2018 | 05:30 PM
2006EvoIXer's Avatar
Try unplugging your a/c clutch and see of your fuse still blows.
Old May 29, 2018 | 05:36 PM
Unplug A-39
Old May 29, 2018 | 06:37 PM
nor11384's Avatar
FCOTM Winner
but its blowing when connecting the battery...what am i testing by doing this?
Old May 29, 2018 | 06:57 PM
if your AC clutch is shorted, disconnecting should prevent fuse from blowing.
Old May 29, 2018 | 07:00 PM
I can't find any schematic of where those 30A fuses go. I'm just guessing it goes to something AC. The other thing I'd suggest disconnecting are the AC fans. Then reconnect one at a time to see which causes fuse to blow.
Old May 30, 2018 | 06:47 PM
nor11384's Avatar
FCOTM Winner
Well, once i connect the battery they blow but once i put in new fuses theyre fine. They blow when connecting the battery...
Old Jun 4, 2018 | 12:22 PM
J_Striker's Avatar
I'll need to look at an electrical diagram, but not many things take 30amp fuses. Look at cooling fans and the blower motor.
Old Jun 5, 2018 | 08:53 AM
nor11384's Avatar
FCOTM Winner
Figured it out. It was the damn system. Ripped out subwoofer with amp and everything and now all is good in the hood sux because I really liked cruising and listening to music.
TJSAP00
Jul 26, 2011 02:08 PM
Nasty2004
Lancer Troubleshooting
Jul 11, 2010 04:43 PM
Daskid
May 16, 2009 11:44 AM
Peteypab2133
Feb 3, 2007 06:13 PM
jtc
Mar 11, 2004 08:02 AM
