Headlight electrical issues
Old Mar 8, 2004 | 01:41 PM
jtc's Avatar
jtc
Okay, electrical engineering people pipe in on this.
I've changed all the bulbs in my headlight assembly to either super-white or LED array, and when I use my turn signals, the blinkers flash super fast.
Is this due to my turn bulbs and running lights having lower resistance than standard filament incandescent bulbs? Or could I have done something to upset the timer for the blinkers?
Check my profile under "exterior" for bulb info. Most of the interior and exterior bulbs have been replaced, wondering if this has affected the electrical system.
Thanks in advance.
Old Mar 8, 2004 | 01:47 PM
CoronaLancer's Avatar
Sounds like one or more of your turn signal lights blew.
Park your car, signal to the left, get out and check that all your corressponding bulbs are working. Then do the same for your right side markers.
Old Mar 9, 2004 | 07:45 AM
jtc's Avatar
jtc
checked everything, all bulbs working fine.
Old Mar 11, 2004 | 08:02 AM
jtc's Avatar
jtc
problem solved. needed LED load equalizers to simulate the ohm resistance of stock bulbs.
lelandjameshart
Lancer Troubleshooting
Nov 15, 2013 09:01 PM
MagicManRed
Jun 27, 2011 04:22 PM
Gambitincognito
14
Oct 25, 2010 07:18 PM
pugi03
Dec 21, 2006 10:07 AM
kbadboy
Feb 8, 2005 05:08 PM
