Brake light on?
Old Apr 11, 2004 | 01:00 PM
needspeedd's Avatar
Brake light on?
well my brake light stays on, it turns of and on randomly. Does anybody know what that might be?
Old Apr 11, 2004 | 01:06 PM
BlewEvo's Avatar
Probably need new brake pads
Old Apr 11, 2004 | 01:17 PM
BlewEvo's Avatar
Let me clarify before someone calls me a retard.
The lightcomes on not only when the Emergency brake is engaged but when the Brake fluid is low.
When your pads are near the end of there life, it takes much more fluid to fill the pistons in the caliper to bring the thin pad near the disc. It probably come one when you brake right? and then goes away whe you start driving? This will get worse until it just stays on.
If you have the stock pads you probably hear squealing from the brakes as the little metal low pad warning thingy is warning you as well.
Old Apr 11, 2004 | 02:26 PM
Space Monkey's Avatar
Check your brake fluid
Old Apr 11, 2004 | 04:04 PM
needspeedd's Avatar
ok thanks for all the suggestions
MARQ
May 8, 2016 07:52 AM
blurr001
Oct 14, 2014 05:26 AM
Jp7
Aug 17, 2009 07:51 AM
AhmadHasib
Feb 24, 2008 05:19 PM
ArchieBabes
May 12, 2005 07:29 AM
