Fuel rail spacer
Old Mar 15, 2019 | 10:21 AM
Rom's Avatar
Rom
Fuel rail spacer
Hi all,
When I put my engine back together again a year ago I couldn’t find the fuel rail spacers so I just used some washers to make one. Of course I wasn’t exactly sure how tall the original ones were so I guessed. I’m thinking that I might have an injector leak issue tho and this might be part of the issue. Does anyone have one lying around they can measure for me by any chance?? I can’t get ahold of one right now (special order everywhere) and I really want to try to solve this leak this weekend.
The Mitsubishi part number is MD095402.
Thanks!
S.
Old Mar 15, 2019 | 11:20 AM
Construct's Avatar
You definitely want to get the proper spacers for this. You won't get the proper spacing and pressure with washers alone.
This is not a good place to cheap out. A boost leak around the injector seals or any fuel-related leaks could easily lead to engine failure or worse. Spend the $20 on spacers now to save yourself from more expensive failures later.
I also recommend performing a boost leak test after seating the fuel rail. I had boost leaks around the injector seals every other year until I machined the Mitsubishi spacers down by about 0.5mm to put more pressure on the injectors. Those injector seals tend to dry out and shrink over time.
Old Mar 15, 2019 | 12:37 PM
Rom's Avatar
Rom
i agree - it’s just an availability (not financial) issue for me - dealer is saying a week to get them, at least. They are only $8 each - just wish I could get some right now!!
thanks!
S.
Old Mar 15, 2019 | 12:42 PM
Evo9isLife's Avatar
5 Year Member
STM has them available, I'm sure they can get them to you quicker than the dealer.
https://stmtuned.com/collections/mit...oem-evo-dsm-3s
Old Mar 15, 2019 | 02:13 PM
Rom's Avatar
Rom
Yeah, I saw it on their site too, and have tried both calling and emailing them - no response yet. I will keep trying. I wanted to get it overnighted (Saturday delivery), but because I couldn't get ahold of them, it's too late now.
Thanks for checking for me tho!
S.
