Hm...possible 6spd conversion?
Old Apr 14, 2004 | 07:36 AM
  #31
Hungbee112's Avatar
I guess I wouldn't mind an extra gear between 4th and 5th as long as 1st-3rd stayed the same. I would hate all those extra shifts in city traffic if they made 1-3 closer.
Old Apr 14, 2004 | 03:27 PM
  #32
steveevo8's Avatar
what the hell replace it with the stock 5 speed.. then just trade it in a few months to get an MR.. if its true of them comign here. then we all will well idk what we would think... ( i'd def be jealous )
Old Apr 14, 2004 | 03:34 PM
  #33
evorent's Avatar
all info PM please
Old Apr 14, 2004 | 04:04 PM
  #34
mifesto's Avatar
yum
Old Apr 14, 2004 | 04:09 PM
  #35
Zeus's Avatar
Originally posted by evorent
all info PM please
That design would be a bit rough for street use...
Old Apr 15, 2004 | 09:42 AM
  #36
Z1 Performance's Avatar
the last thing an Evo needs is a 6 speed IMHO
Old Apr 15, 2004 | 09:50 AM
  #37
Mister2zx3's Avatar
what's the second to the last thing it needs IYO? more power?
Old Apr 15, 2004 | 11:26 AM
  #38
DynoHack's Avatar
Go back to your Z, Adam.
I don't know about anyone else, but there's too much of a gap for me between 4th and 5th. Ideally, I'd want a shorter 4th, something between 4th and 5th for my new 5th and the existing 5th for my 6th.
The Evo "needs" lots of things and I'm not even halfway there yet.
Old Apr 15, 2004 | 12:36 PM
  #39
jemm's Avatar
Shifter Vid #1
I have got a lot of pms about the 6 speed and the shifter mechanism / play etc. I took a short vid ... hopefully if I do get access to the car again, I can take another one with the car driving this time
http://www.rallyjamaica.com/misc/6speed.avi (u may need the mjpeg codec)
Regards,
Jemm
Old Apr 15, 2004 | 12:41 PM
  #40
jemm's Avatar
Originally posted by Secret Chimp
But the UK Evo 8's do not have the same emissions 'stuff' around the gas tank....this stuff takes up much of the room that was once occupied by the ACD/AYC system....Your tanks is completely different. Your ECU's are also different. So it's not just a matter of plugging in a few extra things and suddenly being able to have a 6spd AYC/ACD system under a US Evo VIII....ie it is not a dead simple switch.
The 6speed tranny does not in any way need the active stuff, in fact from what I can tell it should be a direct bolt on to the transfer case with the viscous unit. The gear linkages and the reverse selector (seen in vid) are different and would be needed also.
Old Apr 15, 2004 | 12:43 PM
  #41
jemm's Avatar
Edit : deleted
ooops.. posted twice.
Old Apr 15, 2004 | 02:27 PM
  #42
gtr's Avatar
gtr
Hi Jemm,
The link does not work right now.
Nevermind the site was possibility hammered.
Old Apr 15, 2004 | 03:51 PM
  #43
zstryder's Avatar
Hm, the shifter looks to be really long-throw (more so than the 5 speed), and it does look kind of loose too. Actually, it reminds me a lot of the STi 6 speed. What's up with that?
Old Apr 15, 2004 | 05:14 PM
  #44
jemm's Avatar
It does have a longer throw but is not as loose as it may look in the video... I have yet to miss a gear with rapid shifting. No where as sucky as the STi shifter.
Maybe Cruftydusty or one of the members with the jdm e8 gsr can lend more useful info..
Old Apr 16, 2004 | 12:48 AM
  #45
Crufty Dusty's Avatar
This topic has come up many times and I've gotten into so many flame wars about it. I've owned both the 7 GSR and the 8 with the 6 speed gearbox.
The Evo 7 gearbox (W5M51) is good, but due to the ratios the car feels very weak at the top of 4th into 5th. While it's true that most tracks usually don't allow you enough room to use the top gear, people tend to forget that the ratios are stacked closer together. What this means is that you have options. It's not a sequential gearbox; you can skip gears! Wow, who would've thunk that?
Reliability-wise my car is still pretty much stock with >20K hard-driven miles on it. Yes, my car was affected by the recall, and it involved replacing a tiny pin in the gear selection lever and that's about it.
