Evo 9 Air conditioner help
Old Jul 7, 2019, 01:56 PM
DomeSteez's Avatar
So my ac works and everything. Blows cold. But it doesn’t blow out fast. I’ll put it on the highest setting (4) and it doesn’t come out so fast. What could cause this. ??
Old Jul 7, 2019, 02:07 PM
Received 1,384 Likes on 1,317 Posts
Possible switch failure would be my first guess. Worse case is the blower motor is failing or has losts it ability to cycle the settings
Old Jul 7, 2019, 02:31 PM
DomeSteez's Avatar
What switch?
Old Jul 7, 2019, 02:53 PM
Was thinking the fan switch here?
Old Jul 8, 2019, 07:39 AM
DomeSteez's Avatar
Each sentting works 1.2.3.4 but it’s just not blowing out hard enough.
Old Jul 8, 2019, 08:48 AM
Pull the glove box & remove the filter element just to ensure there is no blockage there!
Old Jul 9, 2019, 02:28 AM
gsr1379's Avatar
Edit:
Disregard. You said all speeds work. As everyone else said. I would change filter and check for blockages.
Does the fan not change speed? or only some of the speeds ( not all 4) if so you can try this
Amazon Amazon
Old Jul 9, 2019, 02:37 AM
Biggiesacks's Avatar
Have you replaced your cabin filter? Might be clogged up
Old Jul 10, 2019, 05:32 PM
barneyb's Avatar
If not the filter then maybe the zone door. Check if the cold air is coming from somewhere other than the dash vents.
