Need help, no power going to ac compressor (evo 8)
Old Jul 15, 2019 | 06:48 PM
Biggiesacks's Avatar
Originally Posted by Ude Lose
Yes I checked for leaks and did not find any...
So you put a vacuum on the system and it held it for at least 30 minutes?
Old Jul 15, 2019 | 07:33 PM
Lumpy Sticks's Avatar
5 Year Member
Note the "at least" part. Very important step that most people/shops dont do.
Old Jul 15, 2019 | 11:58 PM
Fox_IX's Avatar
A completely vacuumed system won't show all leaks. I've had HVAC systems hold max vac for hours without going down, yet they'd start losing refrigerant at like 20-30 psi.
It's still a good idea to check for leaks during the vacuum portion, but you won't know the system is leak-free until you fill the system with R134 and spray soapy water on the connections. If you don't want to waste/leak freon into the atmosphere you can also use an inert gas such as argon for leak testing.
Old Jul 16, 2019 | 07:54 AM
barneyb's Avatar
Checking for leaks and pulling a vacuum are not the same thing.
Old Jul 16, 2019 | 07:56 AM
no, they aren't, but if you can't hold vacuum you for sure are leaking. You shouldn't even attempt to pressurize the system if it won't hold a vacuum.
If this was my car I would just assume a leak and replace all the o-rings and inspect all the pieces for damage/failure.
Old Aug 2, 2019 | 08:58 AM
Ude Lose's Avatar
Just going to bring it to the shop down the street and have them charge and or diagnose the system I dont have time to mess around with it.
Thanks fellas!
Old Aug 6, 2019 | 03:26 PM
barneyb's Avatar
So, what was the damage, what did the shop find?
