Boost leak at valve cover
Old May 4, 2020 | 10:27 PM
envdevo9's Avatar
Hi, I did a boost leak test and noticed I was getting air coming from the valve cover. Air is coming from the nipple that normally goes to the air intake with a hose. I discounted the pvc valve, still happening. The way I have the boost leak tester set up is, directly connected to the air intake. Reason I did it this why is because I'm still running stock bov and intercooling piping, I want to see if its leaking at all the connections, that's why I didn't go straight to the turbo compressor housing. Any thoughts why this is happening?
Old May 5, 2020 | 05:12 PM
hutch959's Avatar
air going down intake, into cylinders, past piston rings... into case then back up the oil galleys to the valve cover... then out the vent
Old May 5, 2020 | 08:34 PM
Turtletron's Avatar
5 Year Member
I believe the hose on the valve cover near the camshaft position sensor connects to the intake hose. So if you're pressurizing it from the intake it's going to blow into the valve cover.
Mine didn't have it on when I bought it so I can't say for sure.
Old May 5, 2020 | 11:07 PM
envdevo9's Avatar
Thanks for the replies.
I have the hose clamped and the nipple is unplugged.
How is it getting to the cylinder, past the throttle body?
Old May 5, 2020 | 11:16 PM
LetsGetThisDone's Avatar
If air didn't bypass the throttle body, the car wouldn't start or idle.
Air goes through.
Old May 7, 2020 | 11:34 PM
envdevo9's Avatar
How much psi are you guys holding when doing a boost leak test? I'm at about 18psi before it starts dropping.
Old May 8, 2020 | 06:06 PM
hutch959's Avatar
with the radio and fan off in the garage.....
ive always just thrown as much air to it as i can.. quickly.. .. then i stop.... and listen
if you got a vacuum leak.. you will hear it.
RLLN247
Aug 17, 2014 05:53 AM
jameswwt
Jun 15, 2013 10:57 AM
boosted2x2
35
Jan 27, 2010 03:08 PM
dudical26
26
Jul 25, 2007 02:25 PM
1killertsi
Jul 13, 2006 05:08 PM
