Common heating problems
Old Jul 9, 2020 | 12:26 PM
Domk20's Avatar
I have a 2005 Evo 8 with about 88k, I just recently had a shop replace the crank position sensor. Driving my vehicle from the shop to my job, as I got closer to my job, i noticed the temp gauge starts going. The fans turn on, the coolant reservoir has coolant, and I don't think its the head gasket, no white smoke. I replaced the oem radiator about 2 years ago to a mishimoto. Any suggestions? Thank you for any help in advance
Old Jul 9, 2020 | 04:39 PM
hutch959's Avatar
does the radiator have coolant?
Old Jul 9, 2020 | 07:43 PM
BLK_EvIL's Avatar
Make sure thermostat is working and coolant is bleed. How's it drive beside the heat issue? Did the shop remove timing belt to do the crank sensor?
Old Jul 12, 2020 | 05:20 PM
barneyb's Avatar
Since engine coolant temperature varies a large amount depending on engine load, Mitsubishi installed a lying gauge. It reads normal over a wide range of temperatures and only reads hot only if really hot. The normal symptom of a blown head gasket is the coolant reservoir filling excessively or overflowing. So, this requires immediate attention. Change the thermostat, change the pressure cap, make sure the radiator is full, make sure the reservoir is full to the full mark and keep checking the reservoir for boiling or overfilling. If it is the head gasket the problem may only occur when the head lifts at full boost.
Old Jul 16, 2020 | 02:48 PM
WRC-LVR's Avatar
/\/\ this BTW be sure the temp sensor wire is clean . its under the top hose going to t-stat housing
Old Jul 19, 2020 | 08:10 PM
gqcode's Avatar
Veteran: Air Force
More than likely your thermostats stuck in the close position. you can remove it since it is summertime and see if the Evo overheat or not.
street2dirt
Jun 21, 2013 06:37 PM
loco21
Oct 22, 2012 08:50 AM
svt_lightning01
Nov 15, 2011 05:25 PM
cbarnicle
May 29, 2011 08:00 PM
Evojj25
16
Mar 22, 2011 09:00 PM
