Fuel pressure drop off.
How quickly should your fuel pressure drop off when the pump is stopped. I have a homemade double pumper and trying to see if the check valve is bad in the pump(s). My gauge drops rather quickly.
Sounds good guys. I was just paranoid that I had a bad pump or leaking Injector. It's still in the 12s up top but I had it dead nuts at 11.8 last time I had the car out. It randomly dropped 20psi if pressure when I went to drive it but I found a broken spring in the regulator. Got it changed out and it actually holds pressure a longer now.
asu11
Jun 26, 2016 05:50 PM
Octane Blue
20
May 13, 2013 03:42 PM
Tailgatepro
May 8, 2010 01:57 AM
