Wiring led to the secondary fuel pump
Old Nov 20, 2021 | 03:44 AM
Wheelspk's Avatar
Hello,
​​​​​​can anyone please show me a diagram and what I would need to install a led as a trigger failsafe when the second pump turns on with the Hobbs switch??
Thanks
Old Nov 22, 2021 | 06:41 PM
blackline's Avatar
5 Year Member
you need a 12v led. Tab the power source on hobbs to the led, ground the led. Mine was setup like that(IIRC). This LED won't tell you if the pump is working, it will tell you if the hobbs/relay are working. If you're using the stock ECU and Tephra V7, you can wire in the o2 and have a AFR/lean safety in conjunction with the led.
Old Nov 25, 2021 | 06:30 PM
Wheelspk's Avatar
I'm using a AEM v2, yes I wanted a safety on the hobbs as it can fail or stop wotking.
Luca Bernardi
Jul 26, 2021 07:16 AM
shadyevo
Jan 3, 2014 08:22 PM
Braydo25
Sep 7, 2011 04:40 PM
o6RSEvo
Sep 11, 2007 04:53 PM
