AEM x series 4 bar boost gauge question
Old Mar 14, 2023 | 10:19 PM
Tyler Ransom's Avatar
Hello,
I am currently getting my evo 8 built. When all is said and done it will be set between 500-550hp as a dd on e-85. I’ve got AEM x series gauges for oil pressure and AFR, so I am looking to stick with that line so everything matches. A couple of questions:
What are some of your opinions about this gauge?
What amount of boost will be required for that hp?
I ask that question so I make sure to get the correct range gauge. Right now I was figuring on the 4 bar gauge.
Thanks very much!
Old Mar 15, 2023 | 05:59 AM
schuhie's Avatar
I am unsure what your setup will be but either a 3 or 4 bar gauge would be enough for a 550 whp setup.
3 bar is about 43psi and 4 bar is about 58 psi.
I run a built 2.0 with an FP Red on E85 and make about 580whp at 37 psi for reference.
Old Mar 15, 2023 | 12:12 PM
That helps a lot. All the x series gauges below the 4 bar go up to 35 psi they say. The next higher one is the 4 bar that goes from 30-60psi I just don’t want to get a gauge that I end up maxing out.
my setup is built 2.0 with a Borg Warner s366sx twin scroll on e85 as well.
Old Mar 16, 2023 | 06:07 AM
schuhie's Avatar
Yea, that 4 bar gauge should be a good plenty for your planned setup. I'd anticipate mid-30s for your setup to get where you are trying to go.
Old Mar 16, 2023 | 08:35 AM
Splendid! Thanx very much for your input. It has been very helpful!
EvoNo0b
Apr 7, 2015 11:26 AM
MrJuls
Sep 20, 2012 03:08 AM
sleeper04
Aug 31, 2009 07:00 PM
Maximum404
Mar 7, 2009 01:22 PM
MirzaJinnah
May 23, 2007 01:44 PM
