Tomei Oil Slicing Baffle plate
Old Apr 23, 2023 | 09:13 AM
krys88's Avatar
How many of you use tomei baffle plate? Does it do any benefits over oem unit? I had oem plate in my car for last 5 years with over 700whp but car was used mainly on the street no autocross and had no problems with oem plate. I am just wondering if I should go with tomei on new build. Thanks!
Old Apr 28, 2023 | 01:20 PM
V.8MR's Avatar
They're cheap enough, and do help keep oil in the pan. I have had one for some time and many others as well.
Old Apr 29, 2023 | 09:43 AM
krys88's Avatar
Thanks for answer. I was reading somewhere that someone was doing some testing that they are not doing any benefits but that might not be true, that's why I am asking for input from people that actually using them. Thanks a lot!
Old Apr 29, 2023 | 10:41 AM
RS200's Avatar
The Tomei windage tray is pretty nice and acts as a crank scraper, too (it wipes the oil off of the rotating crankshaft to keep the balance and prevent windage). The package will save a few horsepower over stock and while it may keep a tiny bit more oil in the pan and prevent the oil cloud around the crankshaft, it is not a replacement for oil pan baffle modifications that keep the oil pickup tube submerged. You can absolutely still run the pickup tube dry on a high-G corner with the Tomei kit in place.
Old May 1, 2023 | 02:01 PM
mitsuatb's Avatar
I kept OEM Baffle and used Cosworth crank scraper Works Motor sports still had them. Cosworth name adds horse power!
Wayne99gsr
Mar 31, 2011 06:56 PM
traitorzxiong
Feb 9, 2011 02:26 PM
EViTZO
Jul 30, 2009 01:35 PM
