2.2L pistons/rods combo help please
Hey guys. I never build 2.2L and I want to build one now. What pistons/rods/crank are you guys using to make 2.2L out of 4g63 block? I have brand new pistons that were originally purchased to make 2.3L ( 608010C) , can those pistons be used to make 2.2L? Thanks!
I found this thread very informative:
https://www.evolutionm.net/forums/ev...ck-thread.html
Good luck!
Good luck!
Good luck!
Good luck!
Thank you so much it is very informative, I just still can't find what pistons do I use to make it 2.2L , I have some 2.3L pistons and not sure if I can use them. Thanks a lot!
Stroker, Destroker, and Long Rod Engine Basics | DSMtuners.com
2.2 Destroker
Standard Specs:
Stroke: 94mm
Factory Bore: 86.5mm
Rod Length: 156mm
Wrist Pin Height: 1.248"
Displacement: 2209cc or 2.2L
Rod/Stroke Ratio: 1.65
Piston Speed @ 1,000RPM: 10.27 FPS
2.2 Long Rod Destroker
Standard Specs:
Stroke: 94mm
Rod Length: 162mm
Wrist Pin Height: 1.012"
Rod/Stroke Ratio: 1.72
2.3 Stroker (4g63 Block/4g64 Crank)
Standard Specs:
Stroke: 100mm
Factory Bore: 85mm
Rod Length: 150mm
Wrist Pin Height: 1.130"
Displacement: 2269cc or 2.3L
Rod/Stroke Ratio: 1.50
Piston Speed @ 1,000RPM: 10.93 FPS
Go for long rod if you can!
I apologize if this is wrong, but it's my understanding that the piston size does not impact whether its a 2.3L or a 2.2L just the crank size which you need a 94mm crank. If you plan on using a 86mm piston, you will have to re-bore the 2.0L block (to go from 85mm to 86mm) and find an appropriate rod for the 2.2L application. Again I do not have any personal experience with this and a very limited knowledge base. Sorry.
Maybe I'm looking at this wrong, but the OP has a stock 4G63 2.0L block and a set of 86mm pistons that he wants to use in a 2.2L stroker motor set up. Wouldn't boring the 2.0L block from 85mm to 86mm accommodate the piston he already has, while using a 94mm crank and the appropriate rod (to eliminate the piston sticking out the block) accomplish his goal?
I'm so confused right now.......
So I pulled the details of the piston part number (608010C) from the original post. It is a Manley stroker 86mm piston with the standard pin height of 22mm. Therefore, in theory, all the OP would need is a 150mm rod (standard EVO spec) and a 94mm crank to accomplish a 2.2L build. This combination should yield a piston deck clearance height of -0.35mm. He would also need a 86.5mm head gasket. Is that correct?
Yes, you are correct. But wouldn't the OP just use a 94mm crank on his 2.0L block and adjust the rod length instead of changing the wrist pin location, which can get complex?
Thank you so much!! Yes those pistons were originally purchase to build 2.3L stroker with 4g63 block with 100mm crank and 150mm rods. The plan has changed and I want to use those pistons only and upgrade wrist pins to make 2.2L if possible. So to do that will I need 94mm crank and 150mm rods? Yes they are 86mm because block was bored to this size.
That's my understanding. But please confirm with an engine builder as my knowledge is theoretical and I have no first-hand experience with a 2.2L build. BTW, Pal215 did bring up some good points (about rod/stroke ratio and cost) that have been heavily discussed on this forum. If you do a quick search you should be able to easily find those posts. Good luck!
The problem is I am the engine builder but it is my first time doing 2.2L. To my understanding if those pistons were purchased to use with 100mm crank and 150mm rods I think I need 94mm crank and 153mm rods to achieve 2.2L but I might be wrong here. Everywhere I search look like those pistons are only to make 2.3L so I am kinda lost here.
https://www.evolutionm.net/forums/ev...-use-2-2l.html
Also, PM LetsGetThisDone. He's pretty knowledgeable and I read good things about his engine builds.
Good luck!
This thread is similar. I used it to determine the required piston wrist pin height during my build. From initial glance, it doesn't look like we can use 2.3l pistons on any version of the 2.2l.
Standard Specs:
Stroke: 94mm
Rod Length: 162mm
Standard Specs:
Stroke: 94mm
Rod Length: 162mm
