Evo 8 with Mitsubishi Mirage aluminum radiator
Old Sep 30, 2023 | 08:43 AM
krys88's Avatar
Does anyone ever tried and run Mirage aluminum radiator on evo 8? The reason I am asking because my radiator touching the turbo and I need slimmer one. Yes I know I can buy slim evo 4 5 6 radiator from stm but it is 899$. I found aluminum Mirage radiator for 150$ that is slimmer than my evo 8 aluminum radiator. It would be enough to clear the space between the turbo and radiator. I was reading somewhere that some people had overheating problem with mirage radiator. Thanks!
Old Oct 2, 2023 | 07:59 AM
schuhie's Avatar
I have no idea but I want to be here in case someone answers. I don't need the extra room but I'd take it lol
Old Oct 3, 2023 | 07:27 PM
osetsky's Avatar
Is it bigger than the Civic rad? We can run those, though at this point I don't recall which gen Civic...
Does it show any mounting measurements?
Old Oct 10, 2023 | 09:51 AM
krys88's Avatar
I ended up buying slim csf radiator. Some people say that the eng was overheating on mirage radiator.
Old Oct 10, 2023 | 01:28 PM
RSMike's Avatar
i've got my old Mirage radiator on the shelf here, it is indeed very thin.
If you're running an aftermarket ECU, I would highly recommend putting a water temp sensor into the lower radiator hose.
I've done that for my Infinite Evo testing car, and it's great to see how much capacity there is in the cooling system.
Engine water temp will typically stay constant, as it's regulated by the thermostat.
But I can see the capacity of the cooling system by looking at the lower radiator temp. Driving to the track it's normally between 15-20c in the lower hose, as the engine load is low.
Some data here below from on track!
Old Oct 14, 2023 | 01:29 AM
JohnpaulZieme's Avatar
I appreciate the info.
Spoiler
KaedynVII
Apr 17, 2023 07:42 AM
walker992
Jun 28, 2016 11:49 AM
boostaddikt
Apr 4, 2014 05:29 AM
owenxguo
Jan 5, 2009 12:04 PM
J!n K@z@mA
Mar 8, 2006 06:45 PM
