Best AWD?
Best AWD?
Want to buy an evo, mostly going to use it on track and some roll racing.
Which of the years havw the best AWD for my purposes (excluding x). I'm assuming 9 or 8 since they're newer, but if they're all the same then I'm going to find an evo 4 since they look the best to me.
How much power can I put to the wheels before needing drag radials for traction?
They are all basically the same. Its going to come down to what you like and whats easy to get parts for.
I'd probably suggest an 8 as they weren't a 1 model year car and are a bit easier to find top end parts for at this point.
Traction wise, it will be based on what you do for suspension and tires. There isn't a simple answer here.
I get liking the understated look of the 4 but it does even have wide body fenders its literally a plain old mirage chassis if you want cp9a id go with the 5/6 but that's your preference. The first model of each generation 1,4,7 are just the worst as they were "experimental" for mitsubishi until the awd got good. For me the 04 rs and the 9 always had The best of everything.
jrsimon27
Mar 27, 2008 11:24 PM
