Turbo manifold to turbo washers
Old Nov 13, 2023 | 09:35 PM
BrunoBoy650's Avatar
I just removed my turbo to send for rebuild and noticed the oem washers weren’t used. It had a single ARP washer under each nut and bolt. The turbo never came loose since I’ve owned the car 14k miles but wondering if anyone else has not used them or if there’s an alternative to them since it seems they’re $7 a washer. Setup is a OG green and FP manifold.
Old Nov 14, 2023 | 08:12 AM
ViciousLSD's Avatar
I just use a basic stud kit with egged copper nuts
Old Nov 14, 2023 | 08:46 AM
Kevin.'s Avatar
Washer's aren't necessarily needed if the nuts used are the serrated flange nut type.
Are you using (4) studs or (4) bolts?
Old Nov 14, 2023 | 08:57 AM
Originally I had ARP hardware that corroded over the last 5 years. I now have the MAPerformance turbo stud kit which is 4 studs and 4 nuts but the nuts are the ones with the “washer” , not just a regular nut.
Old Nov 15, 2023 | 12:18 PM
I can get away using a reg washer and serrated flange nuts?
Old Nov 16, 2023 | 10:16 AM
Kevin.'s Avatar
You can use studs and serrated flanged nuts without washers.
Old Nov 16, 2023 | 05:47 PM
Thank you.
jenick johnson
Nov 29, 2017 06:48 AM
hermesevo8
Nov 17, 2015 06:11 PM
evojanoy
May 6, 2010 10:35 AM
silver_lancer
Lancer Aftermarket Forced Induction Tech
Jan 30, 2005 05:34 PM
evoinit
Jul 17, 2003 09:21 PM
