Fuel smell in the passenger rear wheel well
Old Jan 22, 2024 | 10:58 PM
BrunoBoy650's Avatar
I was adjusting suspension and I smell raw fuel in the right rear wheel area. I haven’t done any sort of fuel related mods in years and no check engine light. Any idea what could be causing this?
Old Jan 23, 2024 | 11:53 AM
Kevin.'s Avatar
Probably charcoal canister vapors, despite being on the opposite side.
Old Jan 23, 2024 | 11:17 PM
could be , I did notice when jacking up the rear of the car today, I did smell fuel on the left side as well. My car has a full tank of fuel if that makes a difference .
Old Jan 24, 2024 | 05:51 AM
DontStopMe's Avatar
Pull the bottom of the rear seat and remove the 2 inspection covers. Take a look around. You may have a leaky gasket that only leaks when the tank is close to full.
See 49 seconds into this video for an issue i had years back.
Old Jan 24, 2024 | 09:19 AM
https://youtu.be/ZbSYBDGH5OA?si=A1R60n-8h_PJyv7w&t=49
thank you! I watch a lot of your videos and they’re very helpful. I do notice my fuel pump whine is much louder over the past few weeks so I don’t know if that is an indication of noise leaking through a seal as well.ill take a look at both sides.
Old Feb 10, 2024 | 06:53 PM
Just to update, yes it was the passenger side gasket. I lifted the seat and fuel smell was heavy under the inspection cover.
Old Feb 10, 2024 | 06:56 PM
My next question though is that this one connector wiggles right and left slightly. Is this normal or is there a seal?
Old Feb 11, 2024 | 11:29 AM
DontStopMe's Avatar
Glad you found it!
Old Feb 11, 2024 | 11:34 AM
DontStopMe's Avatar
the quick connect fuel line? I don't really remember how much it wiggles, but you could compare it to the connection point on the drivers side fuel pump housing. They should feel similar.
Old Feb 11, 2024 | 04:20 PM
thank you! It’s the white connector with the plug. I think it’s the power/ground connector . It wiggles a bit.
Prime12
Jun 5, 2017 02:56 PM
b00st3d.
Jun 22, 2015 07:23 AM
crypto
12
Jan 22, 2007 02:16 PM
DSMEVOLUTION
Jan 7, 2007 06:47 PM
