Evo 8 LINK G4X ECU WHO IS RUNNING IT?
Old Jun 9, 2024 | 08:11 AM
krys88's Avatar
Who is running link g4x ecu on evo 8-9? I have a couple questions. Thanks!
Old Aug 12, 2024 | 10:21 AM
Maikumaru's Avatar
I run the link ECU w evo 9
Old Aug 13, 2024 | 09:05 PM
krys88's Avatar
Thanks for the reply. I thought I had some issues with link 4gx ecu but ended up being hot fuel was changing my Afr to leaner after longer driving. Whenever I was driving longer then 30 min my afr gets leaner by 0.5-0.7 Afr across my fuel map. When I started logging fuel temp I notice that while fuel temp is raising the afr gets leaner. I have 2x walbro 450's so fuel gets pretty hot up to 120F sometimes more on hot days. I made fuel correction to compensate extra 3-4% fuel when fuel temp is raising and it is all good now. The only think that I am still wondering is: are injectors swelling with temperature or really hot fuel need that much correction because of density. Thanks!!
Old Aug 14, 2024 | 02:24 AM
AlexEvo26's Avatar
Are your two pump running all the time ? If yes, not good for fuel as you can see … I think you can control the pumps to make the second running only when needed
Old Aug 14, 2024 | 11:51 AM
krys88's Avatar
No, My first pump working all the time but second is activated with boost, it is turning on above 10psi boost, but still fuel gets pretty hot when I drive it longer then 30 min. I was thinking to install some cooler on return fuel line or something like that, but I did correction in link ecu and at 75F fuel temp I have 0% correction but at 120F fuel I have around 5% correction. Seems a lot for me because when my correction was OFF then my full boost afr 11.5 could climb up to 12.2 when fuel gets hot. I send my fic 2150 for cleaning and flow testing and I also told them to check them with fuel temp change but they found nothing wrong so I guess it is just density of the E85 fuel. From my research e85 fuel boiling point is 173F. and my temp can go up to 120-125F on hot days so not very far from boiling point. I think it is just density of fuel.
Dshen
Apr 4, 2017 05:48 AM
RallySport9
Mar 22, 2017 07:42 PM
racer98
Apr 16, 2005 06:40 PM
amedin12
Jul 8, 2003 06:24 PM
