Need help to rethread lower exhaust manifold stud
Old Oct 25, 2024 | 02:15 AM
03Roush2's Avatar
I have a lower exhaust manifold stud that I want to either put a heli coil or go up a size on the stud.
it’s on the lower exhaust manifold so it has oil on it and I’d really like to not take anything apart. Or the least amount apart. I know there is an oil passage what’s the best way to go about this. Thank you!
Old Oct 29, 2024 | 06:16 AM
blackline's Avatar
5 Year Member
Remove the manifold completely and helicoil.
Old Nov 1, 2024 | 07:46 PM
LetsGetThisDone's Avatar
That oil passage that hole goes into is an oil drain galley, returns oil to the pan. To be super clean about, you can remove the valve cover and oil pan to flush it out when you're done.
Or you can use grease to attempt to drill and tap it with minimal shavings going in.
Old Nov 14, 2024 | 05:35 AM
JacobAllen's Avatar
How is everything going now?
Spoiler
evolved8 bs
Aug 12, 2015 08:46 AM
ms32evoixmr
Jun 14, 2015 07:59 AM
Roberto774
Jan 25, 2014 06:53 PM
strtrcng426
Dec 7, 2008 09:16 PM
