Evo 8 spraying fuel everywhere
Old Aug 23, 2025 | 02:57 PM
AkinaEvo's Avatar
Hello,
I just put my throttle body back on just for the car to start spraying gas once I turn it on. Do I just gotta tighten the flange where it’s leaking from? I’m not sure what happened if I maybe disturbed the line while I was taking the throttle body out.
File Type: mov
Old Aug 23, 2025 | 10:54 PM
ViciousLSD's Avatar
disconnect it and inspect the seal. I forgot what it looks like, maybe an o ring
Old Sep 2, 2025 | 11:10 AM
MasterNater's Avatar
It's hard to tell from the video because the return line is sitting right over the top of the feed line that's leaking. However, it appears that the hard line portion of the feed line is cracked where it meets the flange that bolts to the fuel rail. If that's the case, your best bet will probably be to buy the aftermarket replacement that STM sells here, or see if someone has an oem one laying around they would sell.
Old Sep 2, 2025 | 05:43 PM
carbon_toast's Avatar
5 Year Member
I agree with MasterNater, I have nothing more to add really except a couple pictures.
Shot of frame where the gas starts spraying:
Maybe someone accidentally leaned into the hard line while working on the throttle body and cracked it here:
A crack there would spray upward like the video.
If there is no crack in the hard line then just tighten it and see what that gets you. There is an o-ring in there that should seal the pipe if it's been tightened properly.
Old Sep 3, 2025 | 05:49 AM
Kevin.'s Avatar
Most likely was leaned on during throttle body removal and cracked like stated above
PSA
Aug 17, 2017 03:57 PM
levsh
Nov 25, 2016 06:59 AM
Dmwhite61
Jul 12, 2015 09:14 AM
hamflex
Dec 15, 2006 02:37 PM
EvilBlueEvo8
Dec 8, 2006 04:11 PM
