EVO handling strange
Old Jun 14, 2004 | 03:49 PM
PersianEVO's Avatar
I have just recently bought my evo is has about 2500 miles on it. I'm not sure if this is an evo thing but it seems like the tires folow any imperfection in the road. Even if I take my hands of the well for a second all of a suddent the car immediatly starts going off to the right or left. Is this because of the sensitive steering? Is my alignment off or something or do I need to keep making constant adjustments to avoid immediatly to one side or another????
Old Jun 14, 2004 | 03:51 PM
Revolutionary's Avatar
As some magazine put it, "Trying to drive the Evolution with one hand will require the use of two lanes." Maybe that will put into perspective how sensitive the steering is, and how touchy as well.
If you are still unsure, drop by a shop and have them peep it for you.
Old Jun 14, 2004 | 03:53 PM
BaLListic_EVO's Avatar
its normal.... but i could drive mine perfectly with one hand... those guys must just be wussies in that mag
GottaGoFaster's Avatar
Mine does the same thing too. It will follow any indentations or curves in the road. I had my alignment checked 3 days ago and everything was within specs
Old Jun 14, 2004 | 03:59 PM
dizzigital's Avatar
I had the same problem. I have discovered a solution. Make your own curves and indentations in the road.
Old Jun 14, 2004 | 04:47 PM
g6civcx's Avatar
It's bumpsteer. Hit a bump, ripple, or otherwise an imperfection in the road surface, and the steering wheel follow.
Not much you can do it unless you want to heavily revise the steering.
Old Jun 14, 2004 | 05:21 PM
BMan's Avatar
To stop it you need a much steeper rake (caster). Because the suspension has a shallow rake, it turns quick. Loose the caster, loose the quick steering and it won't 'feel' light anymore.
BMan
Old Jun 14, 2004 | 05:24 PM
NvsEvo's Avatar
the car was built like that for a reason......sharp and precise handling......
Old Jun 14, 2004 | 05:37 PM
TheGVR4kid's Avatar
Someone needs a Cadillac, some warm milk, and a kleenex.
Old Jun 15, 2004 | 08:23 AM
MENTY's Avatar
Go get the alignment checked. Mine would follow ever little crease in the road and after the alignment was fixed it doesnt do that anymore. Check your front tires and make sure they are not wearing only on the inside like mine were. I was only riding on a third of my front tires. Now they are replacing all four!!!! For FREE
Old Jun 15, 2004 | 08:27 AM
westchester evo's Avatar
That is a issue with the stock tires. I put the toyo proxis t-1s and it is a lot less.
Old Jun 15, 2004 | 08:52 AM
WildRice's Avatar
With the factory alignment the front inside edges wear faster than the outside. Playing with the inflation pressures (4 lbs is a bunch, I only adjust mine 2) will change things quite a bit and its easy to do and undo. I am ready for new tires but very much on the fence as to which way to go (looking hard at the new pilots). I am in love with the quick turn in characteristics on this car but am going to tune out some understeer with a bit more rear bar.
Old Jun 15, 2004 | 09:09 AM
MPZ06's Avatar
Check out diferent presure combos, I t made a world of diff.
Hey wild rice the new piolts really do look nice
Old Jun 15, 2004 | 09:12 AM
mifesto's Avatar
this is how the evo is but sometimes the alignment from the factory can be way off... get an alignment done, maybe you have too much toe out
Old Jun 15, 2004 | 09:17 AM
Mui3z's Avatar
its because the stock tires are really sticky
