O2 Sensor Problem...question?
Old Jul 6, 2004 | 12:38 PM
techause's Avatar
I had a shop install my cat back exhaust b/c I did not have access to a lift and I figured they could do the MBC at the same time. Here is the problem, I recently peeked under the car to take a look at the install about a week later. I noticed the plastic covering for the O2 sensor is split at the connection(nearest the mid pipe). Will this cause a problem? Should I put tape over it? If so,what type...it gets really hot over there.
Thanks.
-J
Old Jul 6, 2004 | 12:57 PM
Quickshift's Avatar
You would be fine by just slapping some electrical tape on it. The wires are coated to withstand the heat so you should be fine.
