Wheel Torque Specs?
Old Jul 13, 2004 | 08:04 PM
EvoRs's Avatar
Wheel Torque Specs?
Looked and couldnt find any info on the torque specs for the lug nuts.. Anyone?
Thanks to all who bear with me and answer my questions!
hehe
Old Jul 13, 2004 | 08:12 PM
oguratevo's Avatar
hehe
Set it at 75lb-ft torque and drive for 25miles then re-tighten to 75lb-ft torque.
Old Jul 13, 2004 | 08:23 PM
MANGOOK's Avatar
torque should be 74lbs!
https://www.evolutionm.net/forums/sh...e+specs+wheels
Old Jul 13, 2004 | 08:41 PM
bukhumnoi2000's Avatar
The Mitsu Factory Evo Service manual calls for 73 ft.lb +- 7ft.lb
I normally toque mine right at the upper end of their limit, 80 ft.lb
Old Jul 13, 2004 | 10:21 PM
EvoRs's Avatar
Excellent Thank you...
Old Jul 14, 2004 | 08:20 AM
oak2207's Avatar
Yup, I do 80 as well.
Old Jul 14, 2004 | 11:10 AM
marksae's Avatar
Originally Posted by oguratevo
Set it at 30lb-ft torque and drive for 25miles then re-tighten to 40lb-ft torque.
Damn, I wouldn't want to ride in your car.
Old Jul 25, 2004 | 05:43 PM
machron1's Avatar
First off, torque wrenches measure in ft-lbs not lb-ft. Second, and most important, why would you advise someone to torque their wheels to half of factory specs? There are many ways to lighten your car, but letting your wheels fall off is probably not the best way.
I worked on helicopters in the army for 6 years. A rule of thumb is, you NEVER know the torque unless you look it up. Even if you do the same torque on the same fastener every day, you still don't know the torque of anything. You NEVER know the torque of anything. Helps keep aircraft from falling out of the sky, which is never a good thing.
Old Jul 25, 2004 | 05:59 PM
Zeus's Avatar
80 ft lbs has worked flawlessly for me... max recomended torque.
Old Jul 25, 2004 | 06:01 PM
2k4EvoVIII's Avatar
Yup exactly!!
Old Jul 25, 2004 | 06:06 PM
dpardo's Avatar
Can someone recommend a good torque wrench?
Old Jul 25, 2004 | 06:31 PM
modvp's Avatar
I normally do 90-100 ft.lb for 4 bolt and 80ft.lb for 5 bolt.
Old Jul 26, 2004 | 11:51 AM
BuLocal's Avatar
Snap-on, Mac, Craftsman (cheaper)
Old Jul 26, 2004 | 12:04 PM
leonard_shelby's Avatar
W/ the crapsman you can take it back to sears to have it calibrated once a month if you wish.
Old Jul 26, 2004 | 12:09 PM
AutoXer's Avatar
Side note: Technically, its the same thing... But ft-lb is the common syntax.
I did not know this. Does it state that in the users guide? I sometimes forget and leave mine "torqued up", which will throw off the calibration.
