drop in filter problem
Old Jul 15, 2004 | 08:44 PM
evoVIII_4g63's Avatar
basically i put in a filter and removed the air box and my car is runnin like absolut ****...sounds great but it is SO SLOW....any way to fix this or should i put back in the stock box
Old Jul 15, 2004 | 08:49 PM
BuLocal's Avatar
What kind of filter did you put in? Your probably sucking in a lot of hot air and / or you are now running lean.
mifesto's Avatar
brand?
Old Jul 15, 2004 | 08:50 PM
mifesto's Avatar
and how do you use a drop-in filter if you remove the air box? hehehehehehe
EvolvedDSM's Avatar
You used a "drop in" filter, yet you removed the airbox. I'm confused. Please explain.
Old Jul 15, 2004 | 08:55 PM
MalibuJack's Avatar
LOL I can assume he meant an aftermarket cone filter.. you have two choices, reset the ECU and let it relearn, and it will eventually run similar to before.. or put the stock airbox back on.. Most people feel a difference because of how the air characteristics are changed with the new filter, it upsets the learned settings in the ECU and runs a bit crappy until you drive it for a few days.. but the imediate sensation is it makes the car slower..
I say put the stock airbox back in and get a good panel filter.. with a bone stock car (or even one a pretty highly modified one) the airbox works well until you have a good reason to remove it (Need clearance for intercooler pipes, or some component in the intake forces you to remove it)
Old Jul 15, 2004 | 08:57 PM
EvolvedDSM's Avatar
Well, if the box has been replaced I hope you've still got the MAS on there... and that it's plugged in
Old Jul 16, 2004 | 02:56 AM
yea...cmon im not that dumb....the mass air sensor is on...you can smell the fuel as ur drivin behind me...shot a flame and lot of black smoke, (btw i only said drop in cuz i was talkin to my friend bout gettin the knn drop in cuz it works better than alot of intakes, so i hear)
Old Jul 16, 2004 | 02:58 AM
and resetin the ecu doesnt work....1st thing i tried...im jus goin back to the stock box most likely
Old Jul 16, 2004 | 05:42 AM
evo 8 ya's Avatar
You can either have a drop-in filter (used with the stock air box) or a cone style filter (air box removed) Which one is it? You can't have both.
Old Jul 16, 2004 | 07:01 AM
mifesto's Avatar
i dont think you know what you're talking about, evoVIII_4g63 hehe... you're a very confused person
but back to topic... if you can smell fuel, shoot flames during shifts with alot of black smoke, maybe you should have the dealer check it out because i can safely assume your evo is pretty stock. another alternative is to get a simple mail-in ecu flash from dynoflash... it will reduce bogging, reduce boost taper and increase whp by about 15...
Old Jul 16, 2004 | 07:06 AM
I HAVE A ****IN CONE FILTER!!! I WAS TALKING WITH MY FRIEND WHILE TYPING LAST NIGHT ABOUT GETTIN A DROP IN INSTEAD....THAT IS WHY MY TYPING CAME OUT ALL ****ED UP..PLUS I WAS TIRED AND PISSED...now im jus pissed and really cant type that good lol
Old Jul 16, 2004 | 07:09 AM
SuperHatch's Avatar
You didn't happen to do any damage to the screen on the MAS when you installed your cone filter, did you? Just another possibility...
- Steve
Old Jul 16, 2004 | 08:34 AM
oak2207's Avatar
I have the K&N drop-in. Doesn't really make that much of a difference, maybe a SLIGHT tweak better on the low end, but not much at all. I just like the fact that I can clean it and don't have to buy a new one every time.
Old Jul 16, 2004 | 08:57 AM
Event-Horizon's Avatar
look, cone filters mess with the MAF sensor, it has been explained a dozen times or more. Pretty much every tuner camp does not recommend them unless you are able to get tuning or a reflash.
