Gauge cluster lights failing?
Old Oct 16, 2005 | 01:26 AM
  #31
erioshi's Avatar
Interesting thread - at about 37K my right side cluster bulb went out. The fix took about 15 minutes with a new buld, phillips screw driver and some care taking thing apart and putting them back together again.
IF someone had a camera and some time it would make a quick how-to - although there may already be one.
Old Jan 12, 2006 | 09:02 PM
  #32
Bexa20's Avatar
Anyone knows what is the bulb model that sits in the cluster?? I think there are two types very small ones and the bigger ones. I think the ones lighting up the cluster are the 3 bigger ones, in the middle, and this model I need. I saw that somebody provided the part number for it but that is not what I'm looking for.
Old Jan 13, 2006 | 04:37 AM
  #33
honda-guy's Avatar
it's the 3 larger bulbs, the smaller ones are for warning lights.
i think the reason they burn out so quick is because they are constantly on, even in daytime when your driving lights are not on. get some LEDs so you don't have to replace them again.
Old Nov 12, 2006 | 07:23 PM
  #34
Soon2BEVO's Avatar
A bulb just went out in my car and its making 1/2 of the speedo and 1/2 of the tach dark. Is there only 1 bulb type? I know MR444537 is one of them, just making sure.
Old Nov 12, 2006 | 07:39 PM
  #35
Soon2BEVO's Avatar
Also, I just looked up on Mitsubishi CAPS program and I got 3 different bulbs. THe part numbers are:
MR444536
MN134600
8180A001
Someone on the first page of this thread typed in MR444537 instead of 6...
Old Nov 12, 2006 | 07:49 PM
  #36
rcheung's Avatar
MR444536 - Clear bulb for warning light (SES, SRS, FUEL, DOOR)
MN134600 - Bulb with blue condom for lcd odometer
8180A001 - Bulb with white condom for speedomter and Tachometer(There are two of those so if one goes out, half of the cluster goes out.
MR444537 also says instrument bulb when I look at mitsubishiparts.net . I am not sure what that bulb is for.
Old Nov 12, 2006 | 08:09 PM
  #37
Soon2BEVO's Avatar
I just took out the cluster. There are 16 of the others (MR444536). There is also the one you speak of which I have as part MN134600 (same as you).
However the 8180A001... I have 3 bulbs and also listed as MN134599. EDIT, now I typed in MN134599 is coming up as superceded by MR444537
Old Nov 13, 2006 | 04:35 AM
  #38
Evoryder's Avatar
if removing bulb condoms result in too bright a light...dimm the unit...
Old Nov 13, 2006 | 11:15 AM
  #39
rcheung's Avatar
The thing I don't get is "8180A001" and "MR444537 (MN134599)" seem like they are the same bulb but when you put in the part number in mitsubishiparts.net it comes up with 2 different prices.
Old Nov 13, 2006 | 11:45 AM
  #40
Soon2BEVO's Avatar
Thats exactly the problem I was running into.
However, I called Mitsubishi today and 8180A001/MN134599 is the same part as MR444537. So I ordered 3 of MR444537
Old Nov 14, 2006 | 11:13 AM
  #41
IMR-TIM's Avatar
Thanks for bringing back this thread. Took me 12 minutes last night, start to finish. Now the cluster looks like it should. Nice and bright
Old Nov 14, 2006 | 02:09 PM
  #42
Evoryder's Avatar
ordering mine tomorrow
Old Nov 17, 2006 | 04:23 AM
  #43
Evoryder's Avatar
did this mod yesterday...order 3 bulbs from dealer...he gave me 4 ...that'll work
all i can say is...WOW ..what a change...cluster looks awesome now...my stock units had the white condoms...new ones had the blue...took em' off installed those suckers and "BAM" ...super bright red orange...cost me 8/9 bux at the dealer for the 3 bulbs(4) lol ...definetly do it now if u haven't ! Took 35k for my first bulb to go.
Old Jan 12, 2007 | 11:36 AM
  #44
astrocreep96's Avatar
Sorry to bump an old thread, I'm stopping by the dealer today to pick up some bulbs and I would like this page to reference, just in case. So...tag.
Old Jan 12, 2007 | 11:02 PM
  #45
mitsuorder's Avatar
By all means use it for what it's here for
