Red Line 75W90
Old Aug 16, 2004 | 09:03 AM
  #91
marksae's Avatar
Originally Posted by Kodiak
I EMailed WORKS this question...
"Which fluids do you recommend for transmission, transfer case and differentials on a 2003 Lancer Evolution 8"
Hmmm… I wonder if we can just go by the warm viscosity # when mixing fluids. For example, if we mix two quarts of 75W-90 and one quart of 75W-80, will it equal 75W-86.67?
Old Aug 16, 2004 | 09:26 AM
  #92
TurbotrixRacing's Avatar
Originally Posted by boostedwrx
Ive burnt up 1 transfer case thanks to Redline 75w90. Dont believe me? Ask Buschur, hes burnt up 3. Dont believe that ask Sheppard, he's burnt up a few and only fills it up with the STOCK OEM Fluid, period. It's just the only way the pos transfer case will hold together.
Thats interesting.....I have been using redline 75w90 in my tranfer case since a week after I bought the car. 12k miles later and its still good. Jeff has 32k on his and his is still fine.
Keith
Turbotrix Racing
Old Aug 16, 2004 | 11:24 AM
  #93
marksae's Avatar
I just called Redline. They told me mixing MT90/MTL 1:2 will give me a 75W-85 oil and doing 2:1 will give me really close to 75W-90. So I'll just do a 2:1 mix for my tranny.
Old Aug 16, 2004 | 05:13 PM
  #94
4cefedgst's Avatar
Originally Posted by TurbotrixRacing
Thats interesting.....I have been using redline 75w90 in my transmission since a week after I bought the car. 12k miles later and its still good. Jeff has 32k on his and his is still fine.
Keith
Turbotrix Racing
That should answer everyone's questions right there. The fastest EVO shop has used it with no problems.
Old Aug 16, 2004 | 05:52 PM
  #95
Grod101's Avatar
Keith
Turbotrix Racing
Keith....
didn't your rear TC go on your car at around 700 miles
Old Aug 16, 2004 | 07:01 PM
  #96
EVOTEXAS's Avatar
Guys the TC is NOT the tranny! What is so hard to understand about that!?!?
TurboTrix is using Redline 75W-90 in their TRANSMISSION. So am I. This meets the GL-4 75W-90 requirements set out by the manual exactly.
They are NOT USING IT IN THE TRANSFER CASE.
The transfer case and the transmission both have 75W-90 pumping through them, yes. But there is a totally separate resevior and pathway for the differential in the transfer case (inside and separate from the 75W-90) that uses the SAE90 weight. The fluids do not mix.
So use Redline 75W90 in your TRANSMISSION/GEARBOX/TRANSAXLE and use OEM SAE90 in your TRANSFER CASE and REAR DIFF.
Never confuse the two (or three) again!
Old Aug 17, 2004 | 02:17 PM
  #97
Grod101's Avatar
I'm sorry to inform you but they do use redline fluid in their TC.... and there customers TC's and yes I know there is seperate fills for the front rear and Tranny....
Old Aug 17, 2004 | 11:37 PM
  #98
taylor's Avatar
Any opinions on royal purple max gear sae 90 for the transfer case? It shouldn't cause any problems as it matches the factory reccommendations exactly.
Also, is a 75-90 gl5 or a sae 90 gl5 oil factory reccommended for the rear diff? The small manual that came w/the car didn't specify, it just said mitsubishi gear oil.
Old Aug 18, 2004 | 08:22 AM
  #99
EVOTEXAS's Avatar
I was referring to the post they made talking about the trans. I got a little carried away with my post.
SAE 90 is what needs to be used, not any mixture weight. I am going to try Royal Purple SAE90 in the TC and rear soon.
Old Aug 18, 2004 | 08:33 AM
  #100
marksae's Avatar
Take all the information people say here w/ grain of salt. Just because one shop has been running it w/o any problems (yet), doesn’t mean there won’t be any. Mitsu came up w/ the SAE 90 TC oil requirement for a reason. I’m sure they’ve done way more long term testing than 32k miles. Even BR recommends using the OEM fluids. There have been enough people reporting broken TCs while using redline 75W-90 oil to make me want to stick w/ the right fluids.
Old Aug 18, 2004 | 10:10 AM
  #101
taylor's Avatar
Yea, that sounds like a good idea, too bad it's only avalible in 5 gallon pails . Is SAE 90 required for the rear diff as well? or is it 75-90?
Old Aug 18, 2004 | 10:12 AM
  #102
TampaTurbo's Avatar
Here's another brilliant but probably worthless point. I am not too sure about this but....since this car was designed as a rally car and downgraded as a US version. I would think(not sure) that the fluids that are being used are specifically designed to run in these cars for maximum performance. I figure all those thousands of dollars they used researching and engineering the car, that they wouldnt want to send over a high performance vehicle that falls apart using crappy fluids. my .02. As far as mitsubishi commenting on fluids, I am not sure if we should believe even what they are saying. Afterall, arent they the ones who are voiding warranties for just entering in a scca or whatever event with a completely stock car. Their pushing you to void your warranty. I am not saying there are not better fluids out there, I am just saying its relative to what you are putting it into.
Old Aug 18, 2004 | 10:25 AM
  #103
marksae's Avatar
https://www.evolutionm.net/forums/at...chmentid=41552
Old Aug 18, 2004 | 10:37 AM
  #104
taylor's Avatar
Thank you
I think I'm gonna buy the 5gallon bucket of royal purple. Does anyone know of any problems that may arise form storing opened gear oil for a long period of time? Does it attract water like brake fluid, or "go bad" in any way?
Old Aug 18, 2004 | 11:32 AM
  #105
zmeli's Avatar
maybe you can split it up with other evo owners in your area?
I found the pennzoil 75w-90 synthetic GL-4 gear oil (for the transaxle) but have to buy a whole case of 12 $158.00 in Los Angeles.
maybe you should ask Royal Purple how to store it.
