brake question
Old Aug 19, 2004 | 01:15 PM
gl4662's Avatar
brake question
i brought my evo to the dealer and they said the the sqeauk noise i waas hearing was jsut the trace sqeauk anbd its normal on the evo? is this accurate?
thanks
Old Aug 19, 2004 | 01:20 PM
dpardo's Avatar
I'm not sure if there is a consensus on this or not.
I, personally, have not had any squeaking/squealing whatsoever since I bought the car with 5 miles on the odo. I now have 11k miles.
I broke the brakes in per the dealer recommendations.
Old Aug 19, 2004 | 01:24 PM
plokivos's Avatar
If it's new, yes. They may have not put your shimmy back on.
Semi Metallic brake pads always squeek when its new, but it shouldn't do it all the time.
Check how much padding you have.
Old Aug 19, 2004 | 01:27 PM
yycools's Avatar
yes, if you read the booklet, it'll say the break will make some noise from time to time, its normal for the evo.
Old Aug 19, 2004 | 01:29 PM
gl4662's Avatar
ok noob question what is a shimmy?
and after you break it in will the noise stop?
it gets annoying
