Evolution VIII and MR Cd (Coefficient of Drag)
Old Aug 22, 2004 | 12:26 PM
KnifeEdge_2K1's Avatar
what is the Cd of the VIII GSR and the MR ?
i know the standard VIII GSR's Cd is lower than the VII GSR by 0.01 Cd and the MR is lower than the standard VIII GSR by .05 - .1 Cd but i dont know the VII's Cd so all that info is useless
can anyone shed some light on this?
Old Aug 22, 2004 | 12:35 PM
MisterSpoot's Avatar
Your decimals are off.
If the MR is lower, it'd be lower by 0.005 to 0.01. 0.1 is HUGE. That would be an amazing aerodynamic achievement that would make world news.
Old Aug 22, 2004 | 12:43 PM
Mistasparkle's Avatar
i think our CD is like 15
Old Aug 22, 2004 | 12:44 PM
1QWKEVO's Avatar
no i think our drag coef is like .29 don't quote me on that though...
Old Aug 22, 2004 | 12:52 PM
sarcasm?
Old Aug 22, 2004 | 01:09 PM
0.285 - 0.300 would sound right to me. That massive airdam isn't the most aerodynamic in the world.
Old Aug 22, 2004 | 01:13 PM
EVOTEXAS's Avatar
I think our Cd is more like .31 or .32 or so. My old 350Z with Aero package was like .29 or .30. The Z without the Aero package is .31. There is no way in hell the EVO comes close the the Z's aero.
Old Aug 22, 2004 | 01:36 PM
gtr's Avatar
gtr
cd .36
https://www.evolutionm.net/forums/at...achmentid=8978
https://www.evolutionm.net/forums/sh...highlight=drag
Old Aug 22, 2004 | 01:42 PM
Ha. Doesn't surprise me. We have a fast brick though!
Old Aug 22, 2004 | 02:30 PM
1QWKEVO's Avatar
the Sti's CD is .33 so I doubt are cars are as "brick shaped" as those cars are Our cars are pretty aerodynamic, we just happen to have alot of structures to aid in downforce and under the car things to aid in reducing lift
Old Aug 22, 2004 | 02:40 PM
ferrari 360 is .335 dont trust ur eyes man, and i doubt the 350Z is .31, the NSX is .3 and the Z is way too fat to come close to that
Old Aug 22, 2004 | 02:46 PM
there is no way the sti can have a lower cd then the evo 8 or mr
the hood scoop itself must add .2 to the equation and dont even get me started with that bulbouse front end
Old Aug 22, 2004 | 04:05 PM
EVOTEXAS's Avatar
I work for Nissan, pal. Plus I owned a Z. I think you are the one who is "trusting the eyes." The Z was designed in a wind tunnel. The Ferrari was designed on canvas. I know what I'm talking about. Don't forget it.
Old Aug 22, 2004 | 04:06 PM
EVOTEXAS's Avatar
Clearly you are indeed going by what the car "looks like." Clearly, you have no idea what Cd is or how it is calculated.
Old Aug 22, 2004 | 04:16 PM
1QWKEVO's Avatar
You are incorrect, an object as it gets slicker through the air lowers it DC, and as it gains more drag so does it gain a larger DC. That is as per the definition and mathematical formula of drag coefficent
just to add a note as a compairison (taken off a website):
"The drag coefficient is a number that describes a characteristic amount of aerodynamic drag caused by fluid flow, used in the drag equation. Different objects with the same drag coefficient will behave in similar ways, after scaling for differences in size.
A cylinder is given a default drag coefficient of one. That means that two cylinders of the same size will have the same drag, one twice as large will have twice the drag. Less streamlined shapes will have higher values, while smoother shapes will have lower values.
Automobile Aerodynamics
The drag coefficient ("Cd") is a common metric in automotive design, where designers strive to achieve the lowest possible drag coefficient, and thus lowest possible drag.
This is done to improve fuel economy at highway speeds, where aerodynamic effects represent a substantial fraction of the energy needed to keep the car moving. It is also a factor in sports car design, where low drag, coupled with reduced lift, results in a car which can achieve stability and high top speeds.
The typical modern automobile achieves a drag coefficient of between 0.30 and 0.35. SUV's, with their larger, flatter shapes, typically achieve a Cd of 0.35-0.45. Sports cars can achieve figures of 0.25-0.30, although sometimes designers deliberately compromise drag, in favor of reducing lift."
