Kartboy bushings...shifter base and linkage...Help
Old Aug 31, 2004 | 10:55 AM
mitsuorder's Avatar
I would just call him on something like this. Good luck and let us know what is needed to be done for the install as I am going to be doing the linkage bushings tomorrow or thursday.
Old Aug 31, 2004 | 10:58 AM
MYEVO8U's Avatar
Originally Posted by mitsuorder
93civEJ1, I think that MYEVO8U has the metal shifter base bushings from lancershop like I do. Lancershop includes 8 metal bushings, really only 4 are required. You just need 1 underneath each of the 4 corners of the shifter base. I believe that Kartboy only provides you four so your ok there. As for the under hood bushings I have not installed any yet, my Kartboys should be here this week, I have looked at the stock bushing set up and it looked fairly self explanitory, I think if you still have the stock battery in place then you may have to remove it.
Oh... My bad. I didn't know the kits were different. I do have the metal ones from LancerShop.
BTW you might want to take out the battery. It is a hell of a lot easier. Allthough the metal ones are probably harder to get on, so these might be easier.
93civEJ1's Avatar
called...But answering machine picked up.. The machine said they recommend emailing instead of voicemail because they are frequently traveling.
Old Aug 31, 2004 | 11:01 AM
dailod's Avatar
you have to sand it, i sent a PM to him before i installed it and that's what he told me. its also discussed on this thread:
https://www.evolutionm.net/forums/sh...4&page=3&pp=15
Old Aug 31, 2004 | 11:04 AM
bullfrg's Avatar
Which ones are you doing? I did not have to do anything to mine to make them fit (underhood bushings). Put one half on either side and hooked back up.
93civEJ1's Avatar
sweet...so we sand the base...I will be using exacto knife..or do we sand the bushing?
mitsuorder's Avatar
hey thanks dailod
Old Aug 31, 2004 | 11:05 AM
93civEJ1's Avatar
I will be doing both bullfrg...just started on the base first.
Old Aug 31, 2004 | 11:06 AM
dailod's Avatar
hey thanks dailod
no problem
you gotta remove the whole shifter base to sand the holes which was the worst part of the install.
Old Aug 31, 2004 | 11:07 AM
93civEJ1's Avatar
sweet..be back to tell yall how they are.
Old Aug 31, 2004 | 11:12 AM
mitsuorder's Avatar
93civEJ1, I think this how-to is more of what you are looking for
https://www.evolutionm.net/forums/sh...d.php?p=971480
edit: and here is a how-to pertaining to the install of the lancershop underhood bushings, not Kartboy but some very nice install pics at the bottom of the page.
http://www.norcalevo.net/forums/viewtopic.php?t=657
Old Aug 31, 2004 | 12:31 PM
93civEJ1's Avatar
sweet....thanks..yah...i have looked at all those. I just finished up the shifter base install about 15 mins ago. let me tell you. You will have to do not just a little, but SOME trimming of the holes. I used the exacto knife on the holes and it worked perfectly. BE CAREFUL. there is a brace that the ashtray screw bolts too and the edges of it are VERY VERY sharp...I sliced my hand open and was bleeding like crazy. The bushings are a pain the the butt to put in. Im about to start on the underhood ones in a min. Will let you guys know how it goes as well.
Old Aug 31, 2004 | 12:58 PM
marksae's Avatar
Well, it's too late now since you cut your shifter base, but for future reference I would suggest people cut the bushings and not the shifter base. The reason you'd want to do this is for reversability. If for some reason you decide you want to change your bushings back to stock or to the metal ones, your shifter base holes will end up being too big.
I bought the Kartboy bushings and ended up not using them because I had to cut them too much to make them fit. Instead, I just ripped the energy suspension bushings out of my eclipse and used those instead.
Old Aug 31, 2004 | 12:59 PM
93civEJ1's Avatar
ok...im stuck again....How in the hell do you guys push those bushings in the linkage out ...what did you use??
Old Aug 31, 2004 | 01:00 PM
93civEJ1's Avatar
eh...its no big deal...i didnt take a hugh percent out of it...the stock ones would fit back in just the same if I wanted to throw them in.
