whats wrong with my wipers blades?
When I use my wiper blades in the rain, the rubber blades always skip if theres not enough water on the windshield. On the way up its fine but when coming down which I think the windows are dryer, the blades always skip. My car only has 500 miles on it. I have seen this on other cars but cant remember what is the cause? Do I need to replace my blades or does it have anything to do with my windows being too sticky? It rains alot here and its irritating
the other thing is rubbing alchohal will sometimes soften the blade a little more but if blades sit all summer in the hot sun a lot of times they will need to be replaced that fall when the rain comes again thats just how they are...
Originally Posted by HxllxMan
I had that problem before (30 miles!).... I used a very soft sandpaper on the blade and since the problem is gone. RainX help too.
I think rainX should help do lube the windows a bit
Originally Posted by 1QWKEVO
did u know under 12000 or 1 year miles you have free replacement of wiperblades as well as free adjustments for alignment, clutch, and etc...
The blades look fine, what is causing this? Just want to know incase this crap happens again.
Originally Posted by Derek888
Didnt know that...but I will try the alchohol thing first and then some rainx, if all else fails im headed towards the dealer...
I bet when you take your car to the dealer for warranty work it will void your driveline warranty. Obviously everyone knows that your wiper blades give you adrenaline rush and a need for speed, therefore you raced and broke your wipers. Btw your clutch warranty and everything else is also voided because of elevated wiper abuse. /sarcasm
ECS Performance
Jan 31, 2010 02:51 AM
