-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   How to run 275's? (https://www.evolutionm.net/forums/evo-general/671272-how-run-275s.html)
Viegasjuice Sep 27, 2013 12:13 AM
How to run 275's?
For my next setup I wanna run 275 tires or at the least 265. How can I do this without rubbing if at all possible with no fender modification. Advice greatly appreciated
TougeGod7 Sep 27, 2013 03:12 AM
get an 18x9.5 +40 enkei NT03 or a 18x9.5 +38 enkei rpf1
both will require a 20mm spacer to clear the front brembos
grillpt Sep 27, 2013 04:01 AM
You're still going to have to roll the rears, and possibly/probably run a 5mm spacer out back as well.
in the red Sep 27, 2013 07:34 AM
Enkei GTC01, 18x9.5+38, no spacers, no rolling front or rear and running 275's. Plenty of clearance for the brembo's with this particular wheel. You will have a slight rub on hard lock when parking but other than that things will be fine. I'm lowered on GTWorx springs and have ran multiple track days with this set up.
golgo13 Sep 27, 2013 10:00 AM
Bro.
Do you even search?
https://www.evolutionm.net/forums/ev...el-thread.html
https://www.evolutionm.net/forums/ev...re-thread.html
https://www.evolutionm.net/forums/ev...s-go-here.html
https://www.evolutionm.net/forums/ev...ly-thread.html
https://www.evolutionm.net/forums/ev...elocation.html
:lol:
Viegasjuice, you post a new thread about an old topic covered on EvoM many many times before like once a week.
Dallas J Sep 27, 2013 11:05 AM
Nice, I haven't seen results of the GTC01's yet. I would still throw a ~10mm spacer up front since you have the space to the outside, or should have it. But then again, if it works, it works.
Czarcasm Sep 27, 2013 12:53 PM
Wheel specs in my sig. 20mm spacers needed in front and lots of rolling all around. Coilovers needed also
Im running -3 camber
http://i1321.photobucket.com/albums/...ps1268bfec.jpg
http://i1321.photobucket.com/albums/...ps45913b8c.jpg
Viegasjuice Sep 28, 2013 03:28 AM
I was planning on running some xxr wheels for now. Main thing I was trying to avoid is rub during hard turns.
