How to run 275's?
Old Sep 27, 2013 | 12:13 AM
Viegasjuice's Avatar
How to run 275's?
For my next setup I wanna run 275 tires or at the least 265. How can I do this without rubbing if at all possible with no fender modification. Advice greatly appreciated
Old Sep 27, 2013 | 03:12 AM
TougeGod7's Avatar
get an 18x9.5 +40 enkei NT03 or a 18x9.5 +38 enkei rpf1
both will require a 20mm spacer to clear the front brembos
Old Sep 27, 2013 | 04:01 AM
grillpt's Avatar
You're still going to have to roll the rears, and possibly/probably run a 5mm spacer out back as well.
Old Sep 27, 2013 | 07:34 AM
in the red's Avatar
Enkei GTC01, 18x9.5+38, no spacers, no rolling front or rear and running 275's. Plenty of clearance for the brembo's with this particular wheel. You will have a slight rub on hard lock when parking but other than that things will be fine. I'm lowered on GTWorx springs and have ran multiple track days with this set up.
Old Sep 27, 2013 | 10:00 AM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Bro.
Do you even search?
https://www.evolutionm.net/forums/ev...el-thread.html
https://www.evolutionm.net/forums/ev...re-thread.html
https://www.evolutionm.net/forums/ev...s-go-here.html
https://www.evolutionm.net/forums/ev...ly-thread.html
https://www.evolutionm.net/forums/ev...elocation.html
Viegasjuice, you post a new thread about an old topic covered on EvoM many many times before like once a week.
Old Sep 27, 2013 | 11:05 AM
Dallas J's Avatar
Veteran: Army
Nice, I haven't seen results of the GTC01's yet. I would still throw a ~10mm spacer up front since you have the space to the outside, or should have it. But then again, if it works, it works.
Old Sep 27, 2013 | 12:53 PM
Czarcasm's Avatar
Wheel specs in my sig. 20mm spacers needed in front and lots of rolling all around. Coilovers needed also
Im running -3 camber
Old Sep 28, 2013 | 03:28 AM
I was planning on running some xxr wheels for now. Main thing I was trying to avoid is rub during hard turns.
GTABurnout
Jan 12, 2019 11:50 AM
v8<turbo4
Aug 4, 2015 10:20 AM
boostedwrx
Aug 15, 2009 08:18 PM
dambikeracer
May 26, 2009 12:53 PM
george3
26
Sep 27, 2008 05:18 PM
