What is this area for? Fuel pump cover
https://cimg3.ibsrv.net/gimg/www.evo...a3bddaf50.jpeg What is this socket and what is the function of this portion? When i took out the sensor there is a rubber inside. I have a problem where my pressure is too low, around 0.5 bar so my car could not start. Tried changing with a new pump and it is still the same. Tried rewiring as well. Need help. |
(Post 11856612)
A rubber? Like... a condom?
Originally Posted by gIGoN
(Post 11856733)
thanks for the pic. What is that socket for? what tube is that? I could see a rubber inside it. I'm losing pressure, i'm not sure if this part is the root cause.
(Post 11856743)
Put some arrows on the picture so we know what youre asking
yea, that's the one. There's a socket on that tube. I am wondering what that socket is for and what that tube is for.
That is the low fuel indicator switch.
Maybe this thread can help you figure out your problem: https://www.evolutionm.net/forums/ev...evo-8-9-a.html
Are you installing a Walbro 255 pump? |
Originally Posted by 2006EvoIXer
(Post 11856819)
(Post 11856818)
(Post 11856902)
my pressure is too low even after replacing with a new pump. I dont think the pump is the issue. |
(Post 11856912)
What pump are you using?
Would i loose pressure if theres a leakage at the low sensor tube? |
How did you adjust for 255 being shorter than stock? How did you keep pump from pulling off of grommet? I forgot to look at my pump hanger last night. I'll check tonight if low fuel sensor can leak pressure.
