shift light help
shift light help
ok guys i need help from some one who can help me understand how to wire a shift light to the utec
pin 9-shift light 1
pin 8 shift light 2
pin 3 shift light 3
shift light outputs are pulldown 100ma---are these outputs the ground of the circuit and you get the power from somewhere else
or are they power and you ground somewhere else...
i cant understand how to wire this or if i need to use all three shift light outputs to make it work
regards rick
pin 9-shift light 1
pin 8 shift light 2
pin 3 shift light 3
regards rick
Basically each output is rated for 100mA, so you can't put any huge lights, think LEDS. So you get the 3 ground wires, and just find a switched 12v for them somewhere else. You can just hook up any of them and set them up in the Utec, but it makes sense to use all 3.
so the shift light leads from the utec are power and i need a ground from somewhere else , i dont understand where the 12v switched comes in....the LED's only have two leads ...
regards rick
regards rick
Alchem1st
Mar 15, 2022 08:47 AM
Evo_AK
16
Sep 28, 2015 12:26 PM
tboboy
Aug 7, 2010 03:39 PM
tboboy
Jul 19, 2010 11:21 AM
