AEM UEGO install w/EMS...suggestions..
After flipping through the directions it appears you need to splice in 4(actually 3) wires(power, ground, analog, and serial) The directions reccomend using pin 76 or 75 for the Lambda input(white wire), on the EMS. This would requiring cutting into the harness...which I do not want to do. Is there another way or do I have this install totally wrong?
