Nifty brake cooling ducts
Old Oct 16, 2004 | 04:27 PM
westchester evo's Avatar
Lightbulb Nifty brake cooling ducts
Well here is a cheep way to cool down the calipers and rotors.
1- remove caliper
2- remove rotor
3- remove rear backing plate
4- go to home depot and buy 2.5" vacuum hose and floor nozzle.
5- look at photos
6- it all cost $35.00 and works great!!!!
Attached Thumbnails Nifty brake cooling ducts-p1010005.jpg   Nifty brake cooling ducts-p1010006.jpg
Old Oct 16, 2004 | 09:38 PM
evo82003's Avatar
the poor man way
Old Oct 16, 2004 | 09:41 PM
dizzigital's Avatar
1- remove caliper
2- remove rotor
5- look at photos
good idea man... any way to hook-up the A/C system to them hoses? =) i was thinking of doing the same thing for the amps in my trunk.
Old Oct 16, 2004 | 09:43 PM
dizzigital's Avatar
westchester's got all type of cool little things... any others in effect or in the works? =)
Old Oct 17, 2004 | 04:57 AM
stay tuned for more tips...................
Old Oct 17, 2004 | 09:02 AM
oak2207's Avatar
I don't see why you have to remove the calipers, rotors, and backing plate to put that hose in??
Old Oct 17, 2004 | 09:10 AM
naucrx's Avatar
Hmm, looks like you might have owned a DSM before your EVO.
I was surfing the Lancer Register the other day and I saw someone use something similar to this to cool their brakes. Here's another DIY solution: DIY brake cooling solution
Old Oct 17, 2004 | 09:48 AM
the reason to remove the rotor and caliper is to remove the backing plate behind the rotor. this covers the rotor. it traps all of the heat.the hose can now cool the back of the rotor and caliper.
Old Oct 17, 2004 | 12:08 PM
oak2207's Avatar
Gotcha
Old Oct 19, 2004 | 10:42 AM
Mmmm
Old Oct 19, 2004 | 10:57 AM
plokivos's Avatar
ghetto fabulous!
Old Oct 19, 2004 | 12:06 PM
mayhem's Avatar
Are you using the aluminum LCA as a jack point?
But to critique what looks like a good idea I think you need to get the outlet of that duct work a lot closer to the caliper/rotor. You should also try putting the inlet of it ducting in an area with a greater high pressure zone. Also work on "hiding" the ducting from exposed air to prevent increasing drag underneath the car. That can be a bad place to create drag/turbulence.
I'd try something more this route: http://www.otcevo.com/brakeduct.asp
Old Oct 19, 2004 | 02:12 PM
bolsen's Avatar
I should do this just to keep the brake dust off lol!
Old Oct 19, 2004 | 02:23 PM
dcorn's Avatar
or you can get the ones straight from mitsu when you buy the car and not have to worry about robbing the air from your oil cooler and putting cheap looking hoses under your nice car
Old Oct 22, 2004 | 10:52 AM
rsboy's Avatar
Damn! i thought the evo came with brake cooling air guides?!? might have to look for options now. Nice DIY mods though! good job!
