How do you remove the A-Pillar?
Old Oct 22, 2004 | 04:47 PM
NocturnalEVO's Avatar
i'm going to be installing my DEFI D Boost gauge tomorrow hopefully, I just needed to know how to remove the stock driver side A-Pillar?
I have a autometer single gauge pod for the a-pillar, so I need to install that.
Thanks
Old Oct 22, 2004 | 04:50 PM
wprettyboy's Avatar
it pops off. just pull on it but don't pull fast you have to go slow or it will break.
Old Oct 22, 2004 | 09:05 PM
Where should I start prying from? the top or bottom?
Old Oct 22, 2004 | 09:10 PM
rExTuHfEr's Avatar
vewwwwyyyy carfuwwwyyyy pull fwumm...topp...
Old Oct 23, 2004 | 09:18 AM
LancerEvoMR's Avatar
Moving to Evo How To Questions.
Old Oct 23, 2004 | 10:13 AM
freedom's Avatar
Pull from the top working down. Note that there is a pin at the top and two clips, with the lowest about 60% from the top. The metal clips are attached to the cover and can be damaged when you remove the cover. Check the lower clip for damage. They run $0.90 if you must replace them.
The lower portion of the cover is held to the dash by two long plastic strips that hook into slots in the dash. You will have to pull up and away from the pillar to get the cover free of the dash. I suggest using blue masking tape on the dash area around the piller as the dash pad is VERY easy to damage.
When you put the cover back on expect to push down at the base of the cover to latch the strips into the dash. The bottom of the cover sits 1/8" below the level of the dash. This is normal. If you don't latch it is place the cover will make a buzzing noise at some RPMs. (Trust me on this.)
Old Oct 23, 2004 | 10:27 PM
thanks a bunch freedom, got it off a little while ago. Too bad something came up, and I hadda leave it, gonna have to install the gauge 2morrow hopefully heh.
EVL4B11MR
May 5, 2016 10:32 AM
hachansoo0413
May 22, 2012 10:51 AM
trevor
Northwest Region
14
Sep 20, 2006 06:36 PM
DSMEVO15
Jun 20, 2005 09:16 PM
SubiEvolved
Jan 19, 2005 01:13 PM
