?setting greddy profec bII bc help???
Old Nov 5, 2004 | 07:02 AM
archie001's Avatar
Iv had my greddy profec b II boost controller for a while and i still feel that its set incorrectly . please help
Old Nov 5, 2004 | 07:04 AM
archie001's Avatar
bump
Old Nov 5, 2004 | 07:16 AM
archie001's Avatar
need help will be going to the track tonight
Old Nov 5, 2004 | 07:25 AM
archie001's Avatar
bump
Old Nov 5, 2004 | 07:33 AM
archie001's Avatar
bump
Old Nov 5, 2004 | 07:40 AM
evoego's Avatar
Registered User
give me your settings that you are using now and I can help. I spent an hour of so getting my e-01 setup and they share the same brain so they should work. I have a setting for low(17psi) and hi (20 psi). pm me if needed
Old Nov 5, 2004 | 08:36 AM
archie001's Avatar
bump
Old Nov 5, 2004 | 09:04 AM
PVD04's Avatar
Give more details on what you think is wrong with it. What are the symptoms. It's difficult to diagnose a problem if all you give us is that you think the settings are wrong.
Old Nov 5, 2004 | 09:08 AM
bluebanana23's Avatar
my settings: set 65, set gain 10, gain 6. To tune yours, I suggest you do it in 5th gear without hitting the limiter, my settings do. You will also notice it does not hold boost consistently in every gear, that is why the profec b sucks.
Old Nov 5, 2004 | 09:20 AM
vandammy's Avatar
my setting is set 49 gain 6% set boost 150 warning 210 and limiter 6% too
i forgot some.. not in my car now.... but... everything works fine for me.... boost didn't fall much upon gear change,... found out that u need to toy with the limiter too...
i got a min 19.5+ boost and max 20.3~8 just need more time and concentrate on the boost reading... i gain so much more power compare to the first time i got it... about 9 month ago... hahaha..
the mods i have is just a Greddy BOV thats it......
Old Nov 5, 2004 | 09:31 AM
archie001's Avatar
I REALLY wouldent know just how to explain whats going on with it, one thigs for sure boost is not consitent through out the gears. dose any one have a step by step guide to tuneing the profec
Old Nov 5, 2004 | 09:33 AM
the search button is your friend. If you still can't find then go to the how to section and scroll down.
Old Nov 5, 2004 | 09:49 AM
archie001's Avatar
thanks
Old Nov 5, 2004 | 11:07 AM
M3lachsilber's Avatar
choad
Post this on How To's Questions Tips...
Or search there for your Topic!
Moving Now!
Old Nov 30, 2004 | 06:38 PM
evo_whiplash's Avatar
Found this on the first page of search. Shloud help you.
https://www.evolutionm.net/forums/sh...ost+controller
