clutch line bleed - confused
i like the write up here:
https://www.evolutionm.net/forums/sh...ad.php?t=75633
but the picture isn't too clear. which is the line i need to bleed to get rid of air bubbles? i think the guys at the shop where i had my car got air in the line since my pedal doesn't fully come up anymore.
and i also didn't understand the part about the 'bleeder' - does the line already have one or do i need to buy one and install it?
and does anyone have a good pic of the line?
thanks!
thanks!
The bleeder valve is located below the intake box. Best way to reach it is to take the battery and tray out. Just take the rubber cap off and unscrew the bleeder nut and let the air flow out. Make sure you fill the clutch fluid reservoir (it does not share the brake fluid since it has it's own compartment in the brake reservoir tank).
If this doesn't work, you'll need to press the clutch pedal all the way down and hold it there then unscrew the bleeder nut. After that tighten the nut and release the clutch pedal. Do the process till all the air has been removed.
