Tein Flex coilover install (ProStreetOnline.com)
Old Dec 3, 2004 | 02:19 PM
vtluu's Avatar
Not my article, but I figured it'd be useful to link to it here to save people the trouble of searching for it:
http://www.prostreetonline.com/pso/p...p?articleid=49
Old Jan 16, 2005 | 01:42 AM
bbbwrx's Avatar
You do not need to remove the camber bolt. All you need to do is remove both the bottom strut bolt then the bolt that attaches the arm to the hub. Then you will not lose your camber settings(even thought they will be off spec) This will make sure that they are the same on both sides so the car will not pull side to side and if you can't get and alignment right away your tires should be fine. This is the way I did it. Both ways are fine.
I posted this comment on prostreetonline too.
Ben
Old Jul 19, 2005 | 08:42 PM
exhaust_note's Avatar
what are the factory torque specs?
Old Aug 3, 2005 | 01:38 PM
Evo05lution's Avatar
? is the install the same for the basics too??
Old Aug 5, 2005 | 04:38 PM
Ninj0x's Avatar
URL change: http://my.prostreetonline.com/howto/...p?articleid=49
Old Oct 26, 2005 | 11:21 PM
jaydmeg's Avatar
Link is broken is there a new one ???
Old Oct 31, 2005 | 05:06 AM
kmcconn9's Avatar
both links no good...
Old Oct 31, 2005 | 11:14 AM
lancealot72's Avatar
Is there a how to on the S-tech install? I would like to see if someone can help me out with a few things. Thanks in advance!!
Old Nov 9, 2005 | 02:26 PM
kmcconn9's Avatar
links still no good...
Old Jan 13, 2006 | 07:23 AM
lexat20's Avatar
anbody got a good link for coilover instal
Old Feb 6, 2006 | 10:35 AM
isfaster's Avatar
bump..anyone got a coilover install diy?
Old Feb 12, 2006 | 03:28 PM
AndyBandy's Avatar
i got a quick question since im too nervous to adjust my coilover level myself.
i have the HKS hipermax RS w/ 30 way adjustable, but what im wondering is how you know what level you are on? I know its a newb question, but does it like click or do anything to let you know what level youre on? Or do you have to count threads? I just want a guide to adjust them equally besides counting threads.
Thanks in advance!
Old Feb 26, 2006 | 03:52 PM
boost4u's Avatar
new link
http://diy.prostreetonline.com/howto...p?articleid=49
Old Mar 30, 2006 | 11:46 AM
Wallesasuaz's Avatar
okay, now is this install go the same for the basics on a lancer? I've searched and can't find anything on installation of basics DIY.
Old Apr 20, 2007 | 07:55 AM
truDriver's Avatar
It looks like this is the correct link
Tein Flex Install Evo 8
