where is the ecu on evo ????
Old Dec 13, 2004 | 08:48 AM
jfboy's Avatar
where is it ??? I took the complete engine harness off the car from the fusebox to the other fusebox to the engine harness to the srs unit and I stioll cant figure out where the ecu is...
Old Dec 13, 2004 | 08:50 AM
Whoosh's Avatar
Look behind the glove box!
Old Dec 13, 2004 | 08:57 AM
machron1's Avatar
Can somebody say "do a search" ?????
https://www.evolutionm.net/forums/sh...t=ecu+location
Old Dec 13, 2004 | 09:00 AM
rExTuHfEr's Avatar
^^^^^^^ ditto
Old Dec 13, 2004 | 09:16 AM
sleet's Avatar
Remove the glovebox, and poof!
Old Dec 18, 2004 | 01:15 PM
Evo Police's Avatar
Here's how to remove the ECU bro:
Here is the instructions on how to get me your ECU for the reflash:
Remove negative battery terminal - 10 mm
Open glove box
There is a plastic tab on the back left hand side you push into the glove box
Slightly bend the right wall of the glove box inward as you swing it outwards and the right hand plastic tab will clear the dash
The glove box door swings down and the hinges lift off the dash
Remove the plastic trim piece under the ECU covering the wiring - it just pulls off towards you
Take off 3, 10mm bolts holding ECU - lower ECU
Pull out plugs from ECU - DO NOT pull on wires - pull carefully by the plugs
doncarbone
11
Jun 4, 2016 06:02 PM
doncarbone
May 3, 2016 11:25 AM
Dan@Assaultech
55
May 29, 2012 09:24 AM
chrisff521
Aug 5, 2011 07:56 AM
downshift411
Feb 19, 2008 06:22 AM
