More on Valentine 1 hardwire....
Old Feb 5, 2005 | 07:46 PM
revnine's Avatar
I'm in the process of hardwiring my V1 to the map light console in the MR.
Can anyone help tell me which of the two wires to attach the V1's vampire clip?
There are two black wires--one with a white stripe--that plug into the maplight unit.
The one with the white stripe is hot all the time, but I cannot tell if or when the plain black wire is hot.
Ideally I'd like to hook up to a switched hot wire so I don't accidentally run my battery down if I don't turn off the V1.
Any ideas?
thanks,
Tony
Old Feb 7, 2005 | 11:27 PM
onesicklambo's Avatar
i just wired my v1..but dont use the map lights..just run the wire under the headliner/down the a pillar and to the cigarette lighter..trust me its easy, the v1 came with plenty of wire to go that length..the "phone cord" wire..then the res power wire. It turns on with ignition, and is pretty simple. tap the brown wire behind the cigarette lighter for power.
Old Feb 7, 2005 | 11:44 PM
mitsuorder's Avatar
a little ot but do you guys have the new POP radar update on your Valentines?
Old Feb 8, 2005 | 07:46 AM
asasin79's Avatar
go to autozone or your local parts store and pick up one of these i got mine for my zeitronix for around $8.00. no splicing clean install. slot 10 in the interior fuse box is empty.
Old Feb 8, 2005 | 09:05 AM
mitsuorder's Avatar
niceness
Old Feb 8, 2005 | 09:56 AM
JDM_EVOVIII's Avatar
My V1 is mounted on the passenger side on the rear-view mirror and my hidden display is on my steering column.
Old Feb 16, 2005 | 12:25 PM
mitsuorder's Avatar
check this http://www.540i6.com/jasonsv1.html
Old Feb 16, 2005 | 12:29 PM
sblvro's Avatar
POP2 is new for january, 2005 but I purchased mine december and it came with the POP2 already.
Old Feb 16, 2005 | 12:31 PM
johnnysixer's Avatar
How sneaky of him I wonder if the V1 would fit in our sunglasses holder? That would be clean.
Old Feb 16, 2005 | 01:02 PM
mitsuorder's Avatar
Yeah I just called valentine, mine has been getting weaker and weaker the past couple of months. It was purchased dec '02 and is now out of warranty, they said send it in. Looks like $55 for just the pop update. I have a question. I am admittedly not an electronics person, can solder like a **** but just not that experienced with voltages and what not. I teed off the power line for my Valentine for a constant power to run to my Autometer 60mm egt gauge, could that be what is causing my Valentine not to work at optimal performance?
edit: edited for uber linkage http://www.jaricdesign.com/products.htm
Old Feb 16, 2005 | 01:03 PM
LilJapnBoy's Avatar
i tried using this for my boost gauge backlight but it didn't work, i think i had a defective add a circuit.
does this work real well? if so, i'll try utilizing it again....
Old Jan 6, 2006 | 09:51 PM
rkm625's Avatar
The link to "these" doesn't work anymore. can someone give a discription of it or a new link to one?
Old Jan 19, 2006 | 09:05 PM
asasin79's Avatar
yeah man. i've been using it on my zeitronix since i made that post or before. it didn't work at first, but i rotated it 180* per the instructions and it worked fine. sorry for the delay. this is almost a year old thread.
Old Jan 19, 2006 | 09:06 PM
asasin79's Avatar
"these" is a mini add a circuit. http://www.sportys.com/acb/showdetl....fromgoogle=yes
hope that helps.
Old Feb 2, 2008 | 11:17 AM
Meeyatch1's Avatar
hope that helps.
How do they know which one to send you? My Evo IX seems to have these 'mini' fuses in the in-cabin fuse box, as opposed to my Acura that has larger fuses. The prongs on the Evo fuses seem to be physically smaller.
