Help! 255 in starting out.
Old Feb 28, 2005 | 07:04 PM
Racer1's Avatar
Unhappy Help!car wont start after fuel pump
I installed a walboro 255 fuel pump earlier today and now my car won't start. I depreasurized the fuel system, unhooked - battery cable, took out the pump assembly, and switched out the stock pump for the new. I'm using the stock wires, filter ect. After several hours of fiddling I put the stock pump back in and the car still won't start. The electrical works, I checked all fuses, the starter cranks but the car just won't turn over. Please help!
Old Feb 28, 2005 | 07:39 PM
Racer1's Avatar
bump
Old Feb 28, 2005 | 07:41 PM
evo_dadi's Avatar
did you plug back all 3 hoses?
Old Feb 28, 2005 | 07:49 PM
Racer1's Avatar
yes, and like a dork I color coded them so they'd go back corectly.
Old Feb 28, 2005 | 08:09 PM
evo_dadi's Avatar
did you accidentally bent the fuel level indicator(black rubber) while putting it back in since you said the starter crank but its not pumping gas?it might be seeing empty thats wy it wont start.
Old Feb 28, 2005 | 08:14 PM
Soon2BEVO's Avatar
Try putting back in the stock one see if it works.?
Old Feb 28, 2005 | 08:16 PM
steveevo8's Avatar
maybe fill your car up with a little more gas as well, may be a stupid suggestion but those work sometimes
Old Feb 28, 2005 | 08:32 PM
evo_dadi's Avatar
yeah hedid put the stock pump back on but hes probly at the garage right now trying to figure things out
Tyrel Bursaw
Jul 23, 2018 02:26 AM
Stevie Allen
Nov 8, 2016 04:06 AM
amsevokid
14
Apr 21, 2014 11:59 AM
ultraspeed
Dec 13, 2013 12:45 PM
ctdragon
10
Mar 6, 2005 06:19 PM
