255 pump problems
Old May 24, 2005 | 04:18 PM
gnulooks's Avatar
Just wait for Al to get back to you. The last thing you want to do is go to the dealer and let them flash your car back to normal. If you do this no one will every reflash your car again because of that special new flash that they are using.
Old May 24, 2005 | 06:03 PM
EvoVec's Avatar
Originally Posted by BoostWhore
I think its a tuning problem, you said if you put the stock one in it runs fine right? so warranty deffinately couldnt help you out.
no i said i put the stock one back in and it didnt run at all...wouldnt even start. so that is what is leading me to believe that it is a reflash problem.
I have buschur guys helping me out now so i should get the problem fixed soon... those guys are great!!!!!!
ECU is getting flashed back to stock to see if that is the problem. and if it is i will get a new flash...so it just means my car will be down for a little while longer. I get the ecu back tomarrow so i will post results from that. Thanks for all the help so far though. I just want the problem solved so i can get back to doing what the car was built for....driving it!
Old May 16, 2007 | 03:06 PM
pac74's Avatar
dude I did the same thing you did and my fuel gauge dont work now. Its een down for days now. goodluck with your problem.
