here is how i installed my NX kit.....
The install of this kit took 6 hours. Sorry, but i dont do ghetto jobs. Its clean as he!!. The solenoids are mounted to a mounting tree on the back corner of the valve cover. I used the supplied brackets. The trigger switch is mounted to the throttle body. I made my own bracket. The factory one was to big. Now i sprayed in first and ran through the clutch. not good, so i installed a switch on the shifter and when you shift to second, its armed and sprays. This setup gave me a 12.4 @ 118 MPH. Ime told that that MPH is good for a 11.7 at least. I guess i shift slow. When drilling the trunk, make sure you look out for the subframe. Also the line from the trunk snakes through the rear diff mount to the drivers side then follows all the brake lines to the front of the car then up. My nozzle is 6 inches from the TB. This is a 75 shot and it pulls quite nice. ime running 11.1 to 1 no NX and 10.8 to 1 w/nx. One bottle will last me a year as i only use it once a month.
i thought about putting the switch in several other places, but it had to be within reach so i could deactivate it. After i run, i unscrew the knob and put it away so its out of sight, except at the track, which is twice a year for me. No biggy. The tank will last me a year.
RAY!!! Looks bada$$ man. I need to get back down to Tucson so I can smoke ALL of you! haha, no jk. Im going with the alchy injection through Nick at Precision Dyno! I let you know how it goes. will hopefully be getting that finished by next week, we will see though. you engine bay looks awesome as always. wish i could be down there with all of you, but im trying to make it down there in september. ill talk to you later buddy.
woosh, since the clutch is stock, in first, the engine blasts off and just slips on the clutch. By getting her moving first, the clutch held fine. After a better clutch, ime sure spraying in first will work fine.
Nick, come and get some!!!!
haha, i wish i could get my car down there for a track day with all of you. i was talking to edwin last night for a while. hes thinking of coming up to philly area to visit and check my car out. either way, i will hopefully be going back down to tus soon.
FS[SouthEast]: Ton of NX Nitrous stuff
Shiroi Kitsune
Oct 23, 2015 09:50 PM
jmtx86
Jan 31, 2011 06:49 PM
SmokinJoe
For Sale - Cars For Sale
17
Dec 11, 2006 02:14 PM
