alpine cda-7893
plz help................has anyone installed a alpine cda-7893 in the evo i just bought one i install everything no sound from unit? everything powers on no fuses blown just no sound wtf?
Ok Found The Problem The Alpine Units Need Constant Power From The Battery You Have To Run A 10ga Wire From The Units Yellow Power Wire To The Battery And Make Sure Auxil Input Is On The Off Position If It Is On No Sound Will Come Out.....
lancer02Josh
25
Mar 28, 2004 09:33 PM
7893, alpine, audio, battery, blownfuse, cda, cda7893, fix, fuse, install, installation, installing, output, replacment, sound
