Installing Ralliart Accent Plate
Old Aug 6, 2005 | 02:17 AM
\\MREVO8's Avatar
Just installed this one myself today, and it looks great. Mine came with the instructions in Japanese, so I have translated and re-written them so they make sense in English.
I hope someone finds it useful
To avoid burns, only install this item with the vehicle turned off, and with the engine completely cooled down.
After installing this accessory, ensure that it does not interfere with the hood latch, and that the hood closes completely.
It is recommended you wash and dry the top of the bumper bar before installing the accent plate, as you won’t want dirt or water trapped underneath it once it is installed.
1. Air duct and radiator upper support removal
  1. Remove the two air duct installation clips. This can be done by pressing down on the centre of each clip. The centre section will “click” downwards, and you will then be able to remove the entire clip. Retain these clips for usage later.
  2. Remove the radiator upper support by removing the bolts as indicated in the diagram below. You will need a 12mm socket and torque wrench for this. Once the bolts have been removed, lift both the left and right supports upwards and off the radiator. Put these in a safe place.
  3. Remove the four clips above the grille. This can be done by lifting the centre piece out with your fingernails or using a screwdriver to lever them out gently.
2. Accent plate installation
  1. Position the accent plate as pictured, fitting the air duct on top of the accent plate. Line up all the holes. Once you are happy, continue to the next step.
  2. Replace the radiator supports. Insert the bolts and loosely tighten them using your fingers.
  3. Carefully slide the four included washers under each of the holes above the grille. Insert each of the four included clips into the holes above the grille. Press the centre piece down until it “clicks” in to place, flush with the surround.
  4. Securely tighten the radiator support bolts with a torque wrench.
  5. Replace the air duct clips you removed in step 1a. This can be done by pressing the centre piece down until it “clicks” in to place, flush with the surround.
This is what the finished product should look like. Enjoy!
Attached Thumbnails Installing Ralliart Accent Plate-accentfinished.jpg   Installing Ralliart Accent Plate-accentplate.gif
Old Aug 6, 2005 | 05:03 AM
Robert_K's Avatar
Looks good. Where you buy it? How much?
Old Oct 8, 2005 | 05:48 PM
codgi's Avatar
Useful post
The only thing I can add (I did the install for the GReddy version of this same plate) is that what is not fully explained in step 2e...is that once you remove the air duct clips...the center section is in the down position...what you need to do to re-install them is to "push" the center position into an up position (i.e so the center position is now protuding from the clip and now looks like the removed grille clips). Now you can follow step 2e .
Old Oct 9, 2005 | 03:39 PM
codgi's Avatar
Here's a pic of the GReddy one on my car...the GReddy one doesn't come with any washers like the RalliArt one.
Old Oct 11, 2005 | 06:05 PM
sterdyevo's Avatar
255 will fix it
Old Jan 9, 2006 | 07:21 PM
Smoothgangsta's Avatar
Anyone know the part# for replacement clips. I broke a couple.
Old Apr 18, 2006 | 03:38 AM
Papa_Duece's Avatar
Does anyone know where I can pickup the accent plate?
Old May 8, 2006 | 06:28 AM
\\MREVO8's Avatar
GruppeS have it for you guys in America: http://gruppe-s.com/Evo/evoeng.htm
Old Jul 31, 2007 | 08:08 AM
pkang's Avatar
nice accent plate. how much it run you?
Old Sep 29, 2009 | 11:09 PM
klever's Avatar
My ride came with a generic one with ralliart sticker lol
GrannyShifting
Mar 21, 2017 05:25 PM
Evo_Jay
Feb 18, 2016 10:04 AM
bluewaterDEMON
204
Apr 3, 2014 08:14 PM
Blacksheepdj
Lancer How Tos / Installations
Apr 11, 2008 11:16 PM
livelyjay
Jan 30, 2006 01:43 PM
